6-cell battery and the ext 9-call battery
Senteaf
10:07 PM
I have bought my laptop, with 6-cell battery, and recently I have realized that it is just not enough/ 2.5-3.5 hours are good, but just not good iif you actually want to do something on your computer....
Anyway I heard about external 9-cell battery that can be plugged in to the computer, where can I buy? can you explain how it works please?
Windows 7 Ultimate x64Intel(R) Core(TM) i3 CPU M370 2.40GHz2 GB RAMIntel(R) HD Grpahics (not worth the money)
Lenovo G560(this is a laptop)
2 GB RAM
1360 x 768
A 6 cell battery for a laptop is pretty standard and is usually self contained right within the laptop. You can replace that 6 cell battery, with a 9 cell battery. Since the 9 cell battery has more cells and lasts longer, the battery itself is natually larger. So, they often either stick out of the back or out of the bottom of the laptop. Oh yeah, they also weigh more because of the extra cells.
Windows 7 Ultimate x64Intel Q9550 2.83Ghz OC'd to 3.40Ghz8GB G.Skill PI DDR2-800, 4-4-4-12 timingsEVGA 1280MB Nvidia GeForce GTX570
Self-Built in July 2009
23" Acer x233H
Intel X25-M 80GB Gen 2 SSD
Corsair 620HX modular
Antec P182
stock
ABS M1 Mechanical
Logitech G9 Laser Mouse
15/2 cable modem
they do have the upside of raising the laptop higher thereby giving better airflow as well as the extra power ;)
win 7 ultimate32bit, Win8.1pro wmc 32bitamd phenom x4 9600corsair twinxs 2x2gb2x nvidia 1gb 8500gt
self build
amd phenom x4 9600
asus m2n32-sli deluxe
onboard
23" PB Viseo 233d
maxtor sata 500gb
maxtor sata 320gb
fujitsu sata200gb
oryxx tornado 750w
thermaltake xaser lll
artic freezer64 pro + 7 case fans
I dont want to replace the 9-cell with the 6-cell...I want to buy an external 9-cell battery. When my 6-cell has 0% energy, I will plug in the 9-cell and have another 5-9 hours of working...sounds good indeed, but I dont know if it really works this way.
2 GB RAM
1360 x 768
I've never seen a laptop battery work that way. External (to me) has always meant that part of the battery will be external to the laptop due to it's extra size. I've replaced numerous 6 cell batteries with 9-12 cell batteries at work and at home (just moved my wife's HP from the standard 6 cell to a 12 cell), and it's always involved getting rid of the first battery. In the case of wife's laptop, her battery was only lasting about 30 minutes anyway on a full charge and at about 50% remaining, the laptop would simply shut down. So, I think she had a bad cell...so the 6 cell was junk anyway.
23" Acer x233H
Antec P182
stock
ABS M1 Mechanical
15/2 cable modem
So can I use the battery that way(plug it in)?
'How do I know what battery I have?
2 GB RAM
1360 x 768
