Windows 7: LCD Water Damage, Need Help
31 Dec 2010   #1
Canada
Hi There,
I have A Sony Vaio Laptop, but I split water into the lcd, i have dried it out but the lcd now has bright spots all over it (see attached images) Is there anything that I would be able to do for example maby disassemble the lcd housing and clean the "optical Layer". Any Help Will Be graciously accepted and also Ps. I'm that kinda person that likes to void warranty to the extreme.
****If this is posted in the wrong "area" may a mod please put into the proper spot****
Edit: Sorry Forgot to attach the images
Thanks,
Deven Prasad
LCD Water Damage, Need Help-img_0004-1-.jpg   LCD Water Damage, Need Help-img_0006-2-.jpg
Last edited by devenprasad; 31 Dec 2010 at 04:47 AM.. Reason: Forgot to Insert Jpegs
31 Dec 2010   #2
Bay Area Peninsula
You, as an individual cannot repair the display, you're only hope is to replace it. A company that rebuilds LCD displays might be able to repair it, but it will require replacing some element of the panel assembly itself. Your hope would be to find a replacement LCD unit and change it yourself. A Guy
 LCD Water Damage, Need Help problems?
Similar help and support threads for: LCD Water Damage, Need Help
Will this damage my computer? BSOD Help and Support
Realtek Audio Problems Post Water Damage Sound & Audio
To water cool, or not to water cool...that's the question. Overclocking and Case Mods
Solved 1.1 USB could damage ext Disk..? Hardware & Devices
