hp dv 6000 Remote Control Does Not work
I just purchased hp dv6000, so i am confused now its remote control not working.... any suggestion?
my OS is windows 7 ultimate n 32 bit
Do you have drivers installed?
Did you install or change anything recently that might have changed the settings?
~Lordbob
yes, i have all drivers properly installed and i did not change anything which caused this issue.
What all was done on the computer between it working and not working?
