Windows 7: hp dv 6000 Remote Control Does Not work
24 Jan 2011   #1
Windows 7 Ultimate 32 bit
I just purchased hp dv6000, so i am confused now its remote control not working.... any suggestion?
my OS is windows 7 ultimate n 32 bit
25 Jan 2011   #2
In the Crust
Do you have drivers installed?
Did you install or change anything recently that might have changed the settings?
~Lordbob
25 Jan 2011   #3
yes, i have all drivers properly installed and i did not change anything which caused this issue.
25 Jan 2011   #4
XP / Win7 x64 Pro
What all was done on the computer between it working and not working?
 hp dv 6000 Remote Control Does Not work problems?
Similar help and support threads for: hp dv 6000 Remote Control Does Not work
Remote Control Doesn't Work in Win-7 Hardware & Devices
X360 Remote Control, can't get it to work Hardware & Devices
VMC Remote Control doesn't work with Netflix streaming Media Center
is there a hardware RF PC remote control that will work on win 7 Hardware & Devices
BT problem: Win7~cell phone-remote control doesn't work Network & Sharing
