Not showing CPU FSB speed
  1. Posts : 5
    Win 7 32 bit
    I have ASUS P5B-MX Motherboard, Intel 946GZ Chipset. Intel Core 2 Duo E7200, 1066 MHz FSB bus. DDR2 SD RAM compatible (2 Banks/slots).
    Recently i changed my RAM from 1 GB DDR2 RAM to 2 GB DDR2 RAM in a single slot.
    Previously in Windows 7 it used to show
    Processor : Intel Core 2 Duo CPU E7200 @2.53 MHz 3.6 Mhz.
    but now it is showing it as
    Processor : Intel Core 2 Duo CPU E7200 @2.53 Mhz 2.53 Mhz.
    I suppose it is not showing the additional FSB 1066 Mhz speed.
    Please help!!!
  2. Posts : 102
    Microsoft Windows 7 Ultimate x64 (Build 7601 SP1)
    Download CPU-Z and see what it tells you. When you launch it, click on "Clocks (Core #0)" to change which core it shows.
  3. Posts : 5
    Win 7 32 bit
    Not Showing CPU FSB Speed
    Thanks for your help. I will download it and check the exact specifications.
    Meanwhile, i have also checked the settings in my BIOS. it shows same.
    Intel Core 2 Duo E7200 2.53 Mhz 2.53 Mhz.
    I think it should show 3.66 Mhz. So it is not only a Windows 7 problem.
    What may be the issue?
  4. Posts : 5
    Win 7 32 bit
    CPU-Z report of my computer system
    CPU Arch : 1 CPU - 2 Cores - 2 Threads
    CPU PSN : Intel Core2 Duo CPU E7200 @ 2.53GHz
    CPU EXT : MMX, SSE (1, 2, 3, 3S, 4.1), EM64T
    CPUID : 6.7.6 / Extended : 6.17
    CPU Cache : L1 : 2 x 32 / 2 x 32 KB - L2 : 3072 KB
    Core : Wolfdale (45 nm) / Stepping : M0
    Freq : 1600.1 MHz (266.68 * 6)
    MB Brand : Asus
    MB Model : P5N-MX
    NB : NVIDIA GeForce 7050 rev A2
    SB : NVIDIA nForce 610i rev A2
    GPU Type : NVIDIA GeForce 7050 / NVIDIA nForce 610i (Microsoft Corporation - WDDM)
    DirectX Version : 11.0
    RAM : 2048 MB DDR2 Single Channel
    RAM Speed : 400 MHz (2:3) @ 5-4-4-17
    Slot 1 : 2048MB (6400)
    Slot 1 Manufacturer : Noname
  5. Posts : 4,280
    Sounds as if your board is reporting your CPU's rated speed. 3.66 Would be overclocked and it would only show that if the settings were not set at default. CPU-Z will also only report the 2.53 in most cases unless the CPU is under full load unless you have the Thermal throttling turned off in the bios.
    CPU-z is reporting your ram at 800Mhz speed you will have to change the timings and possibly the voltage to get it to run at 1066 if the board supports that speed ram.
    Fabe
  6. Posts : 5
    Win 7 32 bit
    Where am i supposed to load the default settings? In the BIOS ?
    or should i update using ASUS EZ Flash 2 software....will it work?
  7. Posts : 5
    Win 7 32 bit
    What should be the exact timing and voltage settings to run it at 1066 Mhz ?
  8. Posts : 4,280
    For that I suggest you check with the manufaturers web site or site's specifically for overlcoking boards to get the proper timings as they all differ.
    Providing your board says it can run your Ram at 1066 speeds.
    Go to your boards site a nd download the manual and look at what is the QVL list (Qualified Vendors List) for what Ram to use.
    Fabe
  9. Posts : 6,879
    Win 7 Ultimate x64
    One word, Speedstep,
    SpeedStep - Wikipedia, the free encyclopedia
    which is enabled by default in the bios on your motherboard according to the manual.
    It doesn't,
    ASUSTeK Computer Inc. - Motherboards - ASUS P5N-MX
    2 x DIMM, Max. 4 GB, DDR2 800/667/533 Non-ECC,Un-buffered Memory
    *800 is overclocking speed
    It only supports up to 667 MHz ram, and has to be "overclocked" to run at 800 MHz. If you don't have the manual download it from the Asus link above and go to page 2-21 and it explains the settings and what needs to be changes to get the ram to run at a higher frequency,
  10. Posts : 1,114
    Windows 7 Home Premium 64 bit
    I have a question, if he's only running one 2ghz stick of ram that means it's running in single channel, which means it probably won't run at 1066 am i thinking wrong
