battery not charging more then 91 %
shahab89
10:29 AM
I have acer aspire 5551 , my laptop battery doesnt charges more then 91 % , what are the possible solutions for it ?:confused:
Windows 7 Ultimate 64 bitAMD Athlon2 GBATI Mobility Radeon
Acer Aspire 5551
AMD Athlon
Intel
2 GB
ATI Mobility Radeon
Welcome to Sevenforums,
You might want to fully drain the battery before, then plug it again on wire powered to let it charge 100%.
You can drain it faster if you're on a switchable graphics system by choosing the ATI Performance.
To evaluate to battery performance you can follow this tutorial:
http://www.sevenforums.com/tutorials/4569-power-efficiency-diagnostics-report.html?filter[2]=Power Management
Asus P8Z77-V LE PLUS
Asus Dual-RX480-O4G
Asus IPS 23"
Internal:
500Go Sata 6Gb/s (x2)
500Go Sata 3Gb/s (x2)
SSD 60Go Sata 6Gb/s
Thermaltake Chaser A71
Custom Water Cooling Loop
Cooler Master QuickFire XTi
Razer Imperator 2012 (4G)
IE 11.0.xxx Rtm
See if your laptop has a conditioning utility in it. Older HP laptops used to let you hit F6 or something like that as they booted, and it would bring you to a battery utility that would drain the battery completely, and perform a full charge.
Intel Core i7-2600
Gigabyte GA-P67A-UD3P-B3
Nvidia GTX 470
Dell UltraSharp 2209WA
OCZ ModStream 700W
CoolerMaster HAF 912 Advanced
CoolerMaster Hyper 212 Plus
the laptop get drained fully , but the charging does not get more then 91 % , even if it is plugged for several hours , it keep on charging and still remains on 91 %
Acer Aspire 5551
AMD Athlon
Intel
2 GB
ATI Mobility Radeon
You could potentially have a cell going bad in the battery itself? Have you noticed that the life of the laptop dropping significantly or had it get down to 20% and the laptop just shut off without warning?
Windows 7 Ultimate x64Intel Q9550 2.83Ghz OC'd to 3.40Ghz8GB G.Skill PI DDR2-800, 4-4-4-12 timingsEVGA 1280MB Nvidia GeForce GTX570
Self-Built in July 2009
23" Acer x233H
Intel X25-M 80GB Gen 2 SSD
Corsair 620HX modular
Antec P182
stock
ABS M1 Mechanical
Logitech G9 Laser Mouse
15/2 cable modem
yes battery life has got down , what can be da possible solution for it ?
Acer Aspire 5551
AMD Athlon
Intel
2 GB
ATI Mobility Radeon
Maybe get ready to buy a new battery, use the old one till it won't charge anymore:(
Windows 7 Home Premium 64 bitIntel Core 2 quad Extreme Q9770 @ 3.2 GHz4x2 GB Muskin 1600 MHz ramNVidia GTX 250
Dell XPS 730
NVidia GTX 250
Soundblaster X-Fi Fatality Champion
2 Dell 2007WFP Ultrascans
3360 x 1050
WD Black 1TB sata, 2-WD Black 500 sata, 2-Seagate 500 Go external
1000 Watt
air
MS Natrual Keyboard Pro
Logitech Wireless Trackball
DSL Elite
It can be the fact your using the battery often, but don't let it drain enough then plug it again. Could be bad Power Plan management also.
There's a way i think to reset the memory of the Li-ion battery (if it had retain the last charge). Gonna try to find back that one.
Meanwhile try to manage your Power Plan settings.
http://www.sevenforums.com/tutorials/774-power-plan-select.html?filter[2]=Power Management
http://www.sevenforums.com/general-discussion/99596-windows-7-battery-consider-replacing.html
http://www.sevenforums.com/general-discussion/18312-consider-replacing-your-battery.html
Asus Dual-RX480-O4G
Asus IPS 23"
Internal:
SSD 60Go Sata 6Gb/s
IE 11.0.xxx Rtm
Buy a new battery. Typically a "high quality" lithium ion battery will last 2-3 years. A cheapo lithium ion battery will last 9-18 months.
My wife's HP battery did something similar at about 1 year. I replaced it and it's working great now.
23" Acer x233H
Antec P182
stock
ABS M1 Mechanical
15/2 cable modem
I am having the same issue with my nephew's Acer 5741-A. He's only had it since Christmas, but now it won't charge past 89% - the orange light stays on forever and never goes blue (which indicates fully charged). PParks said that a cheap battery doesn't last long - so do they usually ship cheap batteries with laptops and how much would a quality one cost, that would last for 2-3 years?
He has been using it while plugged in a lot, but surely that should just reduce the battery life, not cause the charging light to stop working properly?
Windows 7 Home Premium 64bitIntel Core 2 Quad Q8400 2.66Ghz4.Gb 240pin DDR2 PC667Mhz PC5300ATI EAH4850 512mb DDR3
Gigabyte GA-P35-S3
Audigy 4
Corsair 650w
A battery can die or have an issue at anytime, regardless of the quality. You just have a better shot at a long life with a high quality one...same with just about anything I guess. As for price, you need to get the part number and then do some research online. Based on where you are, how much a name brand one costs from the OEM, where you shop, etc...the prices can vary in range quite a bit.
Intel Core i7-2600
Nvidia GTX 470
OCZ ModStream 700W
Just remember to use the new battery instead of leaving the laptop plugged in all the time. That shortens battery life as well.
Windows 7 Ultimate x64Core 2 Extreme QX9770 @ 4.3ghz4GB DDR2 1000EVGA 8800GT SSC SLI
Custom Built By Me
EVGA 780i A2
4GB DDR2 1000
EVGA 8800GT SSC SLI
Creative Xifi Xtreme Gamer
Westinghouse L2210NW
2 x 150gb WD Raptors Raid 0 For OS/
750gb Hitachi for Storage
Enermax Galaxy kilowatt Modular
Custom Lian Li Extended ATX
Ultra 120 Lapped with twin 120mm fans
Razor Reclusa
Logitech Optical
Verizon Fios 30mb down / 20mb up
I think that's debatable. I've always run my laptops docked and always had long battery lives. I think using the battery for a short time and recharging will shorten the life.
I would recommend using the battery from time to time, and draining it down before recharging. That should keep it conditioned.
Intel Core i7-2600
Nvidia GTX 470
OCZ ModStream 700W
