Windows 7: [HELP] USB Flashdrive Problem
31 Jan 2011   #1
Windows 7 Ultimate x64 (desktop) / x64 (laptop)
I'm having a problem with this particular USB flashdrive. Whenever it was inserted, USB Disk Security detects it and reports as there's no threat from malwares in the said flashdrive, but it doesn't show up in the 'My Computer' screen. I tried remapping the drive letters of some virtual drives in this PC but it didn't work. The said flashdrive didn't work on 2 PC's now so the USB port of the PC's is definitely out of the problem here. How do we fix this problem? There are important files in it for office work.
02 Feb 2011   #2
The USB Flashdrive is just busted. I'm not sure if it's even fixable.
(Thread Closed)
Search this Thread:
Advanced Search
32 GB flashdrive became 8 MB in size after format.
I have an issue and I hope someone can help me. My 32 GB flashdrive shrink and it became 8 MB in size. Tried the Fat32formatter but was prompted to a message partition collapsed. Checked the disk management but there is no unallocated size. Also tried the disk part but only one disk is being...
Hardware & Devices
UEFI reboot problem after boot to flashdrive
Building a new win7 box using Asus F2A85-V Pro with UEFI bios. Want to avoid an irritating problem found on my other Win7 box built with same mb using UEFI, GPT, Fast Boot. I boot to a flashdrive for clean system backups. Then I remove the flashdrive and try to boot "normally". The default boot...
Installation & Setup
cant access my flashdrive
how do you hack into a flash drive to forcefully remove the write protection. i have a 32 gb USB flash drive and all of a sudden write protection got enabled
Hardware & Devices
WRITE protected Flashdrive
i cant format the flashdrive of my friend because it will prompt "disk is write-protected". There is no switch in it and i think it is a virus, because it was loaded with a bunch of shortcuts and error file names. I tried using Malwarebytes and Avast but still after reboot it is still there and...
Hardware & Devices
Removing U3 from a flashdrive.
I have a couple of flashdrives (USB sticks) with U3 installed, apparently this was used In XP, so far all the tools I've tried to format it have refused to work in Win 7, Does anyone know of a way to remove this U3 partition. My reason for having to get rid of it, my Foxsat HDR will only...
Hardware & Devices
usb flashdrive bsod
hi each and evey time i plug in a usb device i get a bsod here are the details Problem signature: Problem Event Name: BlueScreen OS Version: 6.1.7600. Locale ID: 1033
BSOD Help and Support
