Problems with Razer products / weird HDD error.
Ok so i have been getting ALOT of BSOD from drivers related to devices that are infact razer products, I use Naga/lycosa/megalodon, I dont know if it is the product it self failing or sumthing it not compatable because even if i swap one out i get crashes, could it be a problem using all three at once? and yes I HAVE updated ALL possible device and system drivers.
aswell as when i make a new partition in my HDD to try and reinstall windows fresh it tells me that windows could not find a suitable area or drive to install onto AND even if i create a 400 GB partition it will also give the error that there is not enough space
