Need help and advice "front panel/sound"
reluttr
4:58 AM
My 3rd logitech usb headset conked out today. The stupid things literally have a lifetime of about 3 months before they short out and quit working in one ear... So I started looking around at my replacement choices, needless to say that my choices are severely lacking.
But here are my problems... The front sound ports have never worked on my rosewell case, its like they incorrectly wired them at the factory or something. So I cannot get a regular 3.5mm based headset, unless I want to have to pull out my rig just so I can swap around the audio plugs in the back.
I would just get another usb headset, but none of them seem to have all to great reviews. Plus the USB ports in the front of my computer appear to be wearing out "have had this case for about 5 years now".
So here is what I need advice on... what would be the best choice of action for me to take to fix my problem?
-Should I attempt to replace the defective and worn out usb and sound ports on my front panel? Where would be the best place to get parts to accomplish this?
-Should I just buy a "multi hub" type of device that simply goes in one of the optical drive bays? What would be the best brand to get if I do this? My problem with this though, is that the front hubs never seem to look that great and are usually loaded with things I cannot use like a firewire port.
-Or should I just buy a usb hub and usb based soundcard and just route them to the front from the back of my pc? If I do this, then which ones do you recommend?
Also what brand/model of headset do you guys prefer? I really want a ballance of durability and quality.
Windows 7 Professional x64Intel Core 2 Duo E8400 3.00 GHz6.0GB (2x 2GB & 2x 1GB)EVGA 512-P3-N807-AR GeForce 8800GT AKIMBO 512MB
GIGABYTE GA-EP43-UD3L LGA 775
Intergrated
HP 2009m 20"
1600x900
1x Seagate Barracuda 7200.10 ST3250410AS 250GB SATA - Primary
1x Unknown Emachene 100GB IDE - Backup
1x Unknown Emachene 80GB IDE - Backup
OCZ StealthXStream OCZ500SXS 500W
Rosewill RZS06 SLV Black
Arctic Cooling Freezer 7 Pro CPU Fan
Microsoft Natural Ergonomic Keyboard 4000 v1.0
Logitech Trackman Wheel Optical
3.0 mbps
I'd suggest a USB headset over an analog 3.5mm one. That is just my preference, and however you need to get USB ports to the front of your computer that is most aesthetically and functionally pleasing (I suggest a multi-function unit like this one: Amazon.com: 5.25" Bay Mounted Multifunction Panel: Electronics)
I use the Microsoft LifeChat LX-3000 headset. It's probably the best you can find for the price. There are a lot of better and more comfortable ones but I needed one in a pinch and never got around to replacing it. If you want good depth, this Steelseries (Newegg.com - steelseries Siberia v2 USB Connector Circumaural Full-size Headset - Black - Bulk) goes down to 10hz and has a 112dB threshold before distortion. If that's too much, this Turtle Beach headset Newegg.com - Turtle Beach TBS-2114 Earforce HPA2 5.1 Surround Sound Headset with Amplifier and Removable Microphone will serve you well, too.
Better yet, this is all of NewEgg's headsets listed by overall rating. All USB. Newegg.com - Computer Hardware,Speakers & Headsets,Headsets & Accessories,USB
Windows 7 Ultimate 64-bitAMD Phenom II X6 1090T 3.2GHZG.SKILL RipJaw 3x2GB DDR3-10662x HIS Radeon HD 6850 1 GB
MSI 890FXA-GD70
VIA 8-channel
2x 20 inch Acer LCDs, 1x 32" Sony LCD TV
4480x900
1x Crucial 64GB SSD
3x 1TB HDDs (WD, Seagate, Hitatchi)
1x 500GB Seagate External
Kingwin 1000W Modular
Coolermaster HAF 932
1x 120mm, 3x 200mm, CoolerMaster Hyper 212+
Microsoft Wiresless Mouse 5000
20mbps
Samsung BD-ROM/DVD-RW
