Query fan speed
  1. Posts : 354
    Vista Ultimate 32 bit, Win 7 Pro 32 bit, Win 7 Pro 64 bit
    Query fan speed
    Just fitted an Arctic Cooling Freezer 7 Pro Rev.2 CPU Cooler, but the fan doesn't seem to run very fast.
    Its running at about 750 but the CPU is running at 46c/114.5c, M/board at 21c/69.5 c
    To me its too hot.
  2. Posts : 8,383
    46c is normal for a CPU, did you correctly apply the thermal compound?
  3. Posts : 2,240
    Windows 7 Ultimate 64 bit
    According to the product details it's adjustable with it's RPM settings, it's RPM range is from 900-2500 RPM's. It's also a 4 pin connection, which allows the control of the fan with software, provided that your mobo has a 4 pin connection. What I don't see is a manual fan control built on to it. Try using speedfan to adjust your fan.
    BTW, nice fan.
    SpeedFan - Free software downloads and software reviews - CNET Download.com
