Windows 7: Huge display problem I can't find the fix to, please help
15 Feb 2011   #1
I purchased a new led monitor and everything looked perfect, my son messes around in the windows 7 color calibration settings and all my whites look pink now..I even did a new install and all whites are still pink....im wondering if this calibration is stuck somewhere? i reset the monitor to factory settings as well
16 Feb 2011   #2
when i shut the monitor off and turn it back on, the asus logo is clearly white......when i start the computer up hp logos and everything are pink...even the bg on this forum is a light pink...im desperate any help?
16 Feb 2011   #3
W7 Professional x64
type color into the start menu search bar, and "calibrate display color" should come up.
Run through that and set it how you want it
16 Feb 2011   #4
Whoa! LiquidSnak beat me to it, but I use this instead:
Click Start Orb
Type: dccw <enter>
Follow the instructions
Welcome to SF!
16 Feb 2011   #5
heres the thing...no matter how much i seem to adjust this i cant seem to get it to look like it did when it came out of the box its so wierd
16 Feb 2011   #6
Even still after i calibrate n restart all my whites are pink like my boot menus, the lettering on starting windows...its wierd and annoying...and now even my cursors and stuff are pink its crazy..some of the whites are better now that I adjusted the color calibration but cursors remain pink as well as hp startup logos
16 Feb 2011   #7
After messing with this for hours i just tried connecting the pc to my tv and im still seeing pink so im positive this isnt a monitor issue
16 Feb 2011   #8
win7 ultimate 32bit
do you have a video card??--it's control panel 'may' be the best place to adjust the color--check your color temperature settings (cool=bluish, warm=reddish) also your GAMMA setting can have an affect that could cause the pinkish hue--and--once the settings are in place, they will affect the appearance regardless of the device it's plugged into...of course it's difficult to adjust the color when you're starting with 'pink'
16 Feb 2011   #9
True, but i have even gone to the lengths to delete every partition and start from scratch..ive never had this issue before..possible graphics card failure?
16 Feb 2011   #10
win7 ultimate 32bit
IF you have a separate graphics card AND onboard graphics--try connecting the monitor to the onboard--IF problem goes away--then perhaps the Graphics card is hosed.
Similar help and support threads for2: Huge display problem I can't find the fix to, please help
HUGE problem General Discussion
Huge problem. help please ::) BSOD Help and Support
A huge problem and need help. Graphic Cards
Huge Problem BSOD Help and Support
Huge problem BSOD Help and Support
Network problems?? HUGE FIND! Network & Sharing
HUGE problem Software
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
