Huge display problem I can't find the fix to, please help
JGoat519
4:17 AM
I purchased a new led monitor and everything looked perfect, my son messes around in the windows 7 color calibration settings and all my whites look pink now..I even did a new install and all whites are still pink....im wondering if this calibration is stuck somewhere? i reset the monitor to factory settings as well
when i shut the monitor off and turn it back on, the asus logo is clearly white......when i start the computer up hp logos and everything are pink...even the bg on this forum is a light pink...im desperate any help?
type color into the start menu search bar, and "calibrate display color" should come up.
Run through that and set it how you want it ;)
W7 Professional x64AMD Athlon II X3 445 Rana 3.10 GHzPNY XLR DDR3 1600 4x2GBNVIDIA GeForce GTS 450 (fermi) 1GB GDDR5
Pugh Technologies
W7 Professional x64
MSI 870A-G54
Realtek ALC892 onboard
ASUS VE205t, Viewsonic VX2035WM
1600x900, 1600x1050
977GB Hitachi Hitachi HDS721010CLA332
244GB Western Digital WDC WD2500AAJS-65B4A0
488GB Western Digital WDC WD5000AAJS-00A8B0
488GB Western Digital WDC WD5000AAKS-00UU3A0
Antec EarthWatts EA650 650W
ThermalTake Armor A90 Mid Tower
3x 120mm in, 1x 120mm & 200mm out, self built hydro-cooler
Logitec 55
Razer Deathadder
20 Mbps D/L, 9 Mbps U/L
Whoa! LiquidSnak beat me to it, but I use this instead:
Click Start Orb
Type: dccw <enter>
Follow the instructions
Welcome to SF!
Windows 7 Home Premium x64AMD Phenom II X6 1600T16GB PC3-10700 (1342MHz)ATI Radeon 5770 HD (x2) CrossFire
OEM - Me
GigaByte GZ-990FXA-UD3
On-board RealTek chipset
3x Hanns-G 1920x1080 Monitors
Intel 25-V SSD 40GB: 218 MB/s AT: 0.1ms
Intel X-25M SSD 80GB: 230MB/s AT: 0.1ms
Seagate 750GB: 133 MB/s AT: 13ms (perpendicular storage)
Buffalo HD-PCTU3 1TB External drive
OCZ Stealth X Stream 750W
Cheap (unknown)
HP USB
LogiTech USB
1.5 Mbps - Slow - At the tail-end of a rural network
Printer: Epson Stylus C-84
Scanner: HP 3500C Flatbed
DVD-RW: Plextor
DVD-ROM: Unknown
WEI: 7.4
heres the thing...no matter how much i seem to adjust this i cant seem to get it to look like it did when it came out of the box its so wierd
Even still after i calibrate n restart all my whites are pink like my boot menus, the lettering on starting windows...its wierd and annoying...and now even my cursors and stuff are pink its crazy..some of the whites are better now that I adjusted the color calibration but cursors remain pink as well as hp startup logos
After messing with this for hours i just tried connecting the pc to my tv and im still seeing pink so im positive this isnt a monitor issue
do you have a video card??--it's control panel 'may' be the best place to adjust the color--check your color temperature settings (cool=bluish, warm=reddish) also your GAMMA setting can have an affect that could cause the pinkish hue--and--once the settings are in place, they will affect the appearance regardless of the device it's plugged into...of course it's difficult to adjust the color when you're starting with 'pink'
win7 ultimate 32bitcore2 Extreme QX6850-OCd to 3.15 GHz4 GBNVidia 8600 GT
SALEON model 2.2b
win7 ultimate 32bit
ASUS P5G41-M LE
NVidia 8600 GT
23" acer
one SATA 250GB partitioned equally in half
one SATA 160GB-internal storage
500W Thermaltake
mini tower
True, but i have even gone to the lengths to delete every partition and start from scratch..ive never had this issue before..possible graphics card failure?
IF you have a separate graphics card AND onboard graphics--try connecting the monitor to the onboard--IF problem goes away--then perhaps the Graphics card is hosed.
SALEON model 2.2b
win7 ultimate 32bit
ASUS P5G41-M LE
NVidia 8600 GT
23" acer
500W Thermaltake
mini tower
You appear to have ruled out the monitor.
To rule the Windows OS out of the equation down load a linux bootable distro and see what the colours look like. I suggest Puppy linux.
Edit: Actually just booting from the repair disk should rule the OS out. See if the whites still look pink.
If the problem persists then it must be an onboard graphics card setting. Make sure you have access to the colour adjustment software for the card.
Windows 7x64 Home Premium SP1Intel i7 2600kG.Skill Ripjaws (DDR3-1600) 2x4GBNvidia GeForce GTS 450; Intel HD Graphics 300...
Own build
Intel i7 2600k
ASUS P8Z68 Deluxe
Seasonic M12II 520W
Lian Li Lancool PC-K60
Logitech MK520 (wireless)
Logitech MK520
6-7 Mbps
FireFox
Audio: Logitech Z523 2.1
