What Is Wrong With My Power/Battery/Charger?
Wiegraf
1:03 AM
North Carolina
I said "Power/Battery/Charger" because I am not sure exactly which one of those is messed up.
Heres the thing. A little before February 20th I began experiencing problems with my computer. I would have my computer plugged in to a socket at home, and the charger wasn't recognized. I also had an old battery (it gave me the, "consider replacing your battery" message). Eventually, it just stopped reading the charger entirely.
I got a new battery and a new charger and it worked perfectly for a few days. Now, I am starting to see the same problem, only to a lesser extent. My battery works perfectly, but my charger still requires moving or altering its position to get it to start charging my computer.
This is a brand new official charger, and it is very disheartening to see this happen. What do you think could be the problem? Bad luck and getting a faulty new charger? Is is my port?
Windows 7 Home Premium 64-bit
The fact that you can start getting a charge with manoeuvering the cable around makes me think it's the port. Do you have a local PC shop around you? Shouldn't be that much to test and replace if it's faulty.
Windows 8 ProIntel Centrino Dual Core P7450 2.13GHz4gbATI Mobility Raedon HD3650
Toshiba P300
Windows 8 Pro
4gb
Toshiba MK3252GSX ATA
Wish it were faster
Have you tried plugging the charger into a different ac wall socket? Same problem?
Sony Vaio VPCEB47GM Laptop
Win 7 Pro 64-bit
Intel i5 2.4 Ghz
8GB DDR3
Intel HD 3000
IDT High Definition
15.6 WGXA Anti-Glare LED
1280x800
640Gb 7200rpm
That's what I thought the problem was at first. I was proven wrong when it did it at many different ports though.
And about the computer shop, I think that I could try to find one that could fix it.
Do you know what the price range is though? I asked a friend and he said that replacing a port was so much money that it isn't even worth it and you should just buy a new computer (which I don't have the money to do right now)
According to several repair websites (you can Google "repair computer DC power jack"), the average cost to replace a DC power jack on a laptop computer is about $100-$130. Cost is high because you usually have to pull out the guts (keyboard, fan, memory sticks, mobo, etc.) before you can get to the jack itself. Desktop should be about 1/2 the price - more room to work, easier access, etc.
Have you tried spreading the charger's plug prongs just a bit to get a tighter fit in the ac wall socket?
Win 7 Pro 64-bit
Intel i5 2.4 Ghz
8GB DDR3
Intel HD 3000
IDT High Definition
1280x800
640Gb 7200rpm
Are you plugged in directly to wall socket or surge protector plugged into wall socket?
Take a lamp and check wall socket to see if light comes on.
Edit: Could be a bad Battery Charger!
I have bought batteries and chargers right off the shelf that turned out to be bad!
HP M9077c
ASUSeK
6GB DDR2 6400
GeForce 8500/512MB
Realtek High Def Audio
HP w2408 LCD 24" widescreen
1920x1200
6 pack of Bud
MS wireless Inteli
MS wireless Inteli
