Windows 7: Help me I have serius problem
01 Mar 2011   #1
I want to install a fresh version of windows 7 to me PC
When the pc starts run until the point to ask to press the for boot from cd/dvd
and then nothink happens .
any suggestions
01 Mar 2011   #2
Firstly Welcome To Seven Forums.
Second Can You Tell me if your using a Genuine Copy Of The Windows 7 Installation Disk Or is it a Burnt Copy?
Third What Version Are You Trying To Install? 32 or 64?
01 Mar 2011   #3
i try all the copies legal and unlegal i try and ubuntu just in case that my cd is wrong .and the result is the same.
thanks for your time.
01 Mar 2011   #4
Right the First thing i think of is; are you Burning Your Disks at Max Speed? If you are try burning At 4x As this sometimes burns wrong.
1) Is the Motherboard up to date? Recent Buy?
3) is Have you removed all Usb and Other Ext. Devices When trying to boot from the Disks?
4) Eject the Windows 7 DVD after it freezes, and reinsert it
5) Is the Hard Drive Set up Properly? So Sata set to Compatible in The Bios? Or IDE to Master on the Physical drive?
6) Finaly the only other thing i can think of is What PSU are you Using? Sometimes it doesnt like the Power Supply if your using the new Intel i7 or New Motherboards
02 Mar 2011   #5
Moscow, Russia
HEllo
Have you checked to see what the BOOT order or BOOT sequence is in the BIOS?
I'd double check that fist boot device is the CD/DVD rom even though you are getting the |press any key to boot from cd...|
It can still be an issue on some machines if its not setup this way.
Hope you get it figured out.
 Help me I have serius problem problems?
Similar help and support threads for: Help me I have serius problem
problem event name startup repair offline - slightly different problem General Discussion
Solved Moving windows/icons down problem!! Move right/left/up - no problem General Discussion
Desktop icon problem, programs in start menu problem and more... General Discussion
Cute Html problem and Video full screen problem Software
Problem Reports and Solutions - Change Problem Reporting Settings Tutorials
