Windows 7 - battery problem |
07-01-2009
#1 | | |
battery problem I have a laptop. i install windows7 in it. aafter insatlling it, i have a problem in my Power plan.
my PC is turn off after running on battery.
a blank screen displays and then turning off.
how can i correcti it?
| My System Specs | | System Manufacturer/Model Number Gericom/755CI OS windows7 CPU mobile AMD Athlon(tm) XP-M 2600+, 1514 Mhz, 1 Core(s), 1 Log Motherboard Gericom 755CI 1.0,BIOS: American Megatrends Inc. 1.04G 07/09 Memory 768 MB Monitor(s) Displays 15 inches TFT(XGA 1024x786) Screen Resolution 1024x786 Keyboard compaq Mouse IBM Hard Drives 40GB Internet Speed 512KB |
07-01-2009
#2 | | Windows 7 Ultimate x64 SP1 |
Hi maifs welcome to SF, can you give use the Make and Model of your laptop and fill out your System Specs in your UserCP so we can help you out more.
Also do you have the latest firmware on your laptop for BIOS and all updated drivers and windows updates? | My System Specs | | System Manufacturer/Model Number Custom Build OS Windows 7 Ultimate x64 SP1 CPU AMD Phenom II 1090 3.2 six core Motherboard MSI 890FXA-GD65 Memory 16 gig DDR3 Graphics Card MSI R6950 2gig Sound Card on board Monitor(s) Displays Acer 23inch led Screen Resolution 1900x1080 widescreen PSU CORSAIR Enthusiast Series TX750 V2 750W Case CoolMaster HAF 922 Cooling Box AMD Heatsink/Fan Hard Drives Seagate 1tb SATA6
2x 1tb HITACHI Deskstar Internet Speed Cable 12Mbps/3Mbps |
07-01-2009
#3 | | |
power plans
Quote: Originally Posted by maifs I have a laptop. i install windows7 in it. aafter insatlling it, i have a problem in my Power plan.
how can i correcti it? Hi and welcome to SF
First thing is we need to know all about your computer and OS.
Waitinf for your info
Ken | My System Specs | | System Manufacturer/Model Number HP Pavillion dv-7 1005 Tx OS WCP ONLY CPU 2@2.4 Memory 4 gigs Graphics Card Nvidia 9600M Sound Card HD built-in Monitor(s) Displays 17" Wxga Screen Resolution 1440x900 Cooling none Internet Speed 45Mb down 5Mb up |
07-03-2009
#4 | | |
my OS is Windows7 and pc is a Gericom Humer Advance 2640 DVD+RW.
16bit soundblaster pro competible + AC 97 CODEC , Micro, Stereo Speakers ,
smart Li-Ion 6 cells or 8 cells (4000 mAh) | My System Specs | | System Manufacturer/Model Number Gericom/755CI OS windows7 CPU mobile AMD Athlon(tm) XP-M 2600+, 1514 Mhz, 1 Core(s), 1 Log Motherboard Gericom 755CI 1.0,BIOS: American Megatrends Inc. 1.04G 07/09 Memory 768 MB Monitor(s) Displays 15 inches TFT(XGA 1024x786) Screen Resolution 1024x786 Keyboard compaq Mouse IBM Hard Drives 40GB Internet Speed 512KB |
07-03-2009
#5 | | |
battery problem
Quote: Originally Posted by maifs my OS is Windows7 and pc is a Gericom Humer Advance 2640 DVD+RW.
smart Li-Ion 6 cells or 8 cells (4000 mAh) Are you complaining about a shutdown problem or a battery problem?
07-03-2009
#6 | | |
Quote: Originally Posted by zigzag3143 Are you complaining about a shutdown problem or a battery problem?
Ken shutdown problem not battery problem. | My System Specs | | System Manufacturer/Model Number Gericom/755CI OS windows7 CPU mobile AMD Athlon(tm) XP-M 2600+, 1514 Mhz, 1 Core(s), 1 Log Motherboard Gericom 755CI 1.0,BIOS: American Megatrends Inc. 1.04G 07/09 Memory 768 MB Monitor(s) Displays 15 inches TFT(XGA 1024x786) Screen Resolution 1024x786 Keyboard compaq Mouse IBM Hard Drives 40GB Internet Speed 512KB |
07-03-2009
#7 | | |
shutdown
Quote: Originally Posted by maifs shutdown problem not battery problem. what version of win 7?
07-08-2009
#8 | | |
7100.0.090421-1700_x86fre_client_en-us_retail_ultimate-grc1culfrer_en_dvd
this one | My System Specs | | System Manufacturer/Model Number Gericom/755CI OS windows7 CPU mobile AMD Athlon(tm) XP-M 2600+, 1514 Mhz, 1 Core(s), 1 Log Motherboard Gericom 755CI 1.0,BIOS: American Megatrends Inc. 1.04G 07/09 Memory 768 MB Monitor(s) Displays 15 inches TFT(XGA 1024x786) Screen Resolution 1024x786 Keyboard compaq Mouse IBM Hard Drives 40GB Internet Speed 512KB |
07-08-2009
#9 | | |
shutdiwn problem
Quote: Originally Posted by maifs 7100.0.090421-1700_x86fre_client_en-us_retail_ultimate-grc1culfrer_en_dvd
this one At this point it might just be easier to upgrade to the most recent build its 7260 (32 bit) and it might cure uour porblem
07-10-2009
#10 | | |
i upload all my system specifications.
you may check it.
if you can then help me. | My System Specs | | System Manufacturer/Model Number Gericom/755CI OS windows7 CPU mobile AMD Athlon(tm) XP-M 2600+, 1514 Mhz, 1 Core(s), 1 Log Motherboard Gericom 755CI 1.0,BIOS: American Megatrends Inc. 1.04G 07/09 Memory 768 MB Monitor(s) Displays 15 inches TFT(XGA 1024x786) Screen Resolution 1024x786 Keyboard compaq Mouse IBM Hard Drives 40GB Internet Speed 512KB battery problem problems? All times are GMT -5. The time now is 09:38 AM. |  |
