front usb not usb 2.0 help
  1. Posts : 347
    windows 7 64 bit premium
    My 4 front usb are only working at 1.1 speed,as every time i connect my mp3 player it says this device can perform faster if connect to a usb port in bold!
    I have usb 2.0 on my mobo and it shows i have the port.
    My gaming cas says 4 front usb 2.0 ports aswell
    I wired them to the usb 1 and usb 2 pins on the mobo.
    I cannot find why this is ,the back usb work fine in usb 2.0
    ANy help to this problem please!!!
    If you need info my specs are below!!!
  2. Posts : 347
    I also contacted gigabyte the mobo maker and they said they should be working in usb 2.0!
  3. Posts : 11,408
    ME/XP/Vista/Win7
    Is the cable you are using USB 1?
  4. Posts : 1,872
    Windows 10 Pro x64, Windows 8.1 Pro x64, Windows 7 Ultimate x64 SP1,
    Is this something that just happened?
    Have you installed SP1 for Windows 7?
  5. Posts : 347
    It allways been usb on front,im using cables that come from the new case usb !!
  6. Posts : 347
    The case says front usb 2.0 x 4.cables came with the case
  7. Posts : 11,408
    ME/XP/Vista/Win7
    Are any cable's from front USB's to Device's, USB 1?
  8. Posts : 347
    do you mean the grey cables that come from the front usb,,and how do i tell the difference?
  9. Posts : 11,408
    ME/XP/Vista/Win7
    The cable will be marked, HI-SPEED USB Revision 2.0 for USB2, NO marking for USB1.
  10. Posts : 347
    the cables are plain grey?but the case specs say 4 x front usb 2.0 sklots ?
