Even if the port is USB2.0 and the device is 2.0 if you use a USB 1.1 cable, it is going to operate at that speed.
[QUOTE=p5bdkw;1303671]Hello,
Please correct your specs, the mobo info you give, I don't think is incorrect. :)
In your BIOS, you have the "On-Chip USB" option, set it to the default setting.
[/QUO
I got another mobo question if you can find the time to digest it!
My side fan has a 3 pin connector.i have a sys header 4 pin slot on my mobo free,will this control the fan speed to temperature of system or cpu.
Also how do i connect 3 pin to 4 pin!i can give pics if needed
Turns out i been using a usb 1.0 lead,never knew i owned one.
Had a look at my leads and found one with high speed written on cable now everything works fine.
