front usb not usb 2.0 help
sinbin
MR poon
Power User
9:45 PM
My 4 front usb are only working at 1.1 speed,as every time i connect my mp3 player it says this device can perform faster if connect to a usb port in bold!
I have usb 2.0 on my mobo and it shows i have the port.
My gaming cas says 4 front usb 2.0 ports aswell
I wired them to the usb 1 and usb 2 pins on the mobo.
I cannot find why this is ,the back usb work fine in usb 2.0
ANy help to this problem please!!!
If you need info my specs are below!!!
windows 7 64 bit premiumq6600 2.4 overclocked to 3.2 ghz4 gb 800 mhz corsairgtx 480 mbfg o/c
home build/gigabyte mobo
gigabyte ga_73pvm.s2h rev 1.0
gtx 480 mbfg o/c
onboard realtek hd audio
benq 24 inch (led)
1920x1080p
barracuda 7200rpm 320gb
jeantech 900watts
Novatech prowler midi tower v2 gaming case
artic cooling 7 pro rev 2.0, 120mm front,rear and side
saitek eclipse 2
mad catz mw2 laser mouse
50mb virgin
Adding a raptor hdd for gaming use only.
I also contacted gigabyte the mobo maker and they said they should be working in usb 2.0!
gtx 480 mbfg o/c
benq 24 inch (led)
1920x1080p
jeantech 900watts
saitek eclipse 2
50mb virgin
Is the cable you are using USB 1?
ME/XP/Vista/Win7
ME/XP/Vista/Win7
Is this something that just happened?
Have you installed SP1 for Windows 7?
Windows 10 Pro x64, Windows 8.1 Pro x64, Wind...INTEL i9-7920X LGA 206664 GB (4 X 16 GB) G-Skill V Series DDR4 3200 ...EVGA GTX 1060 SC 3 GB
Windows 10 Pro x64, Windows 8.1 Pro x64, Windows 7 Ultimate x64 SP1,
Gigabyte X299-WU8 F3
64 GB (4 X 16 GB) G-Skill V Series DDR4 3200 Quad Channel
Realtek Onboard ALC1220
2 x Samsung S27E310
Samsung 2 x 970 EVO Plus 500 GB NVMe
1 x 6TB WD 6003FZBX SATA
1 x 6TB WD 60EFRX SATA
12 x 3TB WD 30EFRX SATA
Seasonic X-1050
Thermaltake Armor+
Corsair H80i V2 Liquid AOI Cooler
Logitech G510s
Logitech MX Master 2S
200 Mb/s
ESET NOD32 13.1
EDGE (Dev, Canary, Beta), Chrome
ASUS RT-AC68U router
Malwarebytes 4.0.4
It allways been usb on front,im using cables that come from the new case usb !!
gtx 480 mbfg o/c
benq 24 inch (led)
1920x1080p
jeantech 900watts
saitek eclipse 2
50mb virgin
gtx 480 mbfg o/c
benq 24 inch (led)
1920x1080p
jeantech 900watts
saitek eclipse 2
50mb virgin
Are any cable's from front USB's to Device's, USB 1?
ME/XP/Vista/Win7
ME/XP/Vista/Win7
do you mean the grey cables that come from the front usb,,and how do i tell the difference?
gtx 480 mbfg o/c
benq 24 inch (led)
1920x1080p
jeantech 900watts
saitek eclipse 2
50mb virgin
The cable will be marked, HI-SPEED USB Revision 2.0 for USB2, NO marking for USB1.
ME/XP/Vista/Win7
ME/XP/Vista/Win7
the cables are plain grey?but the case specs say 4 x front usb 2.0 sklots ?
gtx 480 mbfg o/c
benq 24 inch (led)
1920x1080p
jeantech 900watts
saitek eclipse 2
50mb virgin
Even if the port is USB2.0 and the device is 2.0 if you use a USB 1.1 cable, it is going to operate at that speed.
Windows 7 Home Premium 64bitIntel Core i3 380M(2.53GHz)4GB DDR3 1066Intel HD Graphics 128MB VRAM
Acer Aspire TimelineX AS4820T-6645
4GB DDR3 1066
1366x768
640GB 5400RPM SATA
Hello,
Please correct your specs, the mobo info you give, I don't think is incorrect. :)
In your BIOS, you have the "On-Chip USB" option, set it to the default setting. ;)
Windows 7 Home Premium 64 bitIntel Core i7-4790G.SKILL 8GB (2 x 4GB) DDR3 F3-10666CL9D-8GBNTAMD Radeon R7 250
Intel Core i7-4790
GA-Z87X-D3H
AMD Radeon R7 250
Realtek ALC892
1920 x 1080, 1280 x 1024
WD5003AZEX
WD10EZEX
Samsung HD103SJ
Samsung 128 GB 840 PRO
SeaSonic M12II SS-500GM
Fractal Design Define R4
Zalman CNPS9900ALED
Logitech K800
Logitech M705
16 Mbps
Hello,
View attachment 144775[/QUO
I got another mobo question if you can find the time to digest it!
My side fan has a 3 pin connector.i have a sys header 4 pin slot on my mobo free,will this control the fan speed to temperature of system or cpu.
Also how do i connect 3 pin to 4 pin!i can give pics if needed
gtx 480 mbfg o/c
benq 24 inch (led)
1920x1080p
jeantech 900watts
saitek eclipse 2
50mb virgin
Hello,
Ive seen this optin in my bios,,what do i do to each setting in the pic ?
I use tons of usb gadjets and really would like to use the 4 front usb at 2.0 speed thanks for any help!
Oh thanks for heads up on mobo info,,changed it have no idea why i typed that ;)
Sorry, I didn't make it clear.:)
There are 3 options.
Of the three options, use "V1.1+V2.0 Enables the integrated USB 1.1 and USB 2.0 controllers. (Default}"
You probably have it set to "V1.1 Enables only the integrated USB 1.1 controller"
Intel Core i7-4790
GA-Z87X-D3H
AMD Radeon R7 250
Realtek ALC892
WD5003AZEX
WD10EZEX
Samsung HD103SJ
Zalman CNPS9900ALED
Logitech K800
Logitech M705
16 Mbps
Hello,
According to the manual, yes.
There system fan has a notch for a 3 pin fan. Just plug it in.
Be sure to enable "System Smart FAN Control" in the BIOS.
Intel Core i7-4790
GA-Z87X-D3H
AMD Radeon R7 250
Realtek ALC892
WD5003AZEX
WD10EZEX
Samsung HD103SJ
Zalman CNPS9900ALED
Logitech K800
Logitech M705
16 Mbps
Turns out i been using a usb 1.0 lead,never knew i owned one.
Had a look at my leads and found one with high speed written on cable now everything works fine.
gtx 480 mbfg o/c
benq 24 inch (led)
1920x1080p
jeantech 900watts
saitek eclipse 2
50mb virgin
You are welcome.
ME/XP/Vista/Win7
ME/XP/Vista/Win7
Thanks i should of checked this first ,but did,nt think i owned a usb 1 lead!
gtx 480 mbfg o/c
benq 24 inch (led)
1920x1080p
jeantech 900watts
saitek eclipse 2
50mb virgin
