Toshiba Sound Device Help
drlamp716
9:34 PM
I recently upgraded my girlfriend's computer from Windows Vista to Windows 7 Professional (32 bit). Everything seemed to be working fine, but when she opened up Skype for the first time, she found that Skype no longer recognized her microphone. In fact, when I go to the audio manager, the microphone shows up as a device, but doesn't recognize any of the sounds I make. I was wondering what the problem is with this; is it a problem with Windows 7, is she missing a driver, or what?
The computer is a Toshiba Satellite M305-S4910. Here are the specs:
Memory*
4GB PC6400 DDR2 800MHz SDRAM
Display Size
14.1" widescreen
Display Type*
WXGA with TruBrite® Technology
Display Resolution
1280x800, Supports 720p content
Graphics Engine*
Intel® Graphics Media Accelerator 4500MHD
Graphics Memory*
128MB-1759MB dynamically allocated shared graphics memory
Hard Drive*
320GB HDD (5400rpm)
Optical Drives*
DVD-SuperMulti (+/-R double layer) with Labelflash™ drive supporting up to 11 formats
Webcam
Webcam and microphone built into LCD bezel
FM Tuner with Antenna
No FM Tuner with Antenna
Wireless LAN*
Intel® Wi-Fi Link 5100AGN (802.11a/g/n)*
Bluetooth
No Bluetooth (No Antenna)
Inputs and Controls
touch pad pointing device, Media button, CD/DVD Buttons (Play/Pause, Stop, Prev Track, Next Track), Mute button, 86 key US keyboard
LAN
10/100 Ethernet LAN
Audio
Microphone jack (mono), Headphone jack (stereo), harman/kardon® stereo speakers, Built-in microphone, S/P DIF output port (shared with headphone port)
AC Adapter
75W (19V 3.95A) Auto-sensing, 100-240V / 50-60Hz input
Battery
Li-Ion (7200mAh)
PC Express Slot
1-ExpressCard™ Slot
Media
S/P DIF output port (shared with headphone port), 5-in-1 Bridge Media Adapter
USB Ports*
1-eSATA/USB (2.0) combo port with Sleep and Charge*, 2-USB (2.0) ports with Sleep
and Charge*
iLINK
i.LINK™ IEEE-1394
Windows 7 Professional 32 bit
Sound recording is not recognised just in Skype? Did you try to record sound in Windows(With Sound Recorder)?
Windows 10 Pro x64Intel Core i5 4440 @Stock4 x 4GB HyperX Fury DDR3Gigabyte GTX 1050Ti O4G
Gigabyte Z97 D3H
Dell P2417H
Riotoro Onyx 750W
NZXT H500 Black-Red
Modecom Volcano Lanparty
DOCSIS 50/3 Mbit
What I had to do is go to the Toshiba support site and download and install the appropriate conexant sound driver for my Toshiba.
Go here Toshiba Support - Homepage and click on Product Support, find your system and then your driver. Should fix your mic problem.
Hope it helps.
Windows 7 x64 UltimateIntel(R) Core(TM)2 Duo CPU P7450 @ 2.13GHz4.00GBMobile Intel 4 Series Express Chipset Family ...
Toshiba P305-S8910
Satellite P305
4.00GB
Mobile Intel 4 Series Express Chipset Family v8.15.10.1872
High Definition Audio Device Harmon/kardon speakers
Generic PnP - Mobile Pc Display
1440 x 900 True Color (32 Bit)
TOSHIBA MK4058GSX ATA Device (IDE)
WD 1600BMV External USB Device
15 mb
