No battery meter showing with UPS installed
I own an APC UPS, model BR800. It is a relatively modern unit, and connects to my Win 7 Pro 64 bit computer.
The APC UPS comes with "PowerChute software." I have had endless, serious problems with this software, and would rather use Windows 7 to control the UPS instead.
I uninstalled the PowerChute software, uninstalled the device drivers, re-started the computer and then plugged the USB data cable back in. Windows 7 reported that it found the UPS unit and installed the drivers successfully. When I check 'device manager,' I see the drivers listed. All appears well.
Unfortunately, no battery meter appears in the system tray, and I can't configure Windows 7's handling of the UPS. I clicked 'customize' in the system tray, and 'Turn System Icons on or off.' The selection for Power is grayed out; I can't change it from off.
Can anyone tell me what I can do to get the battery meter in the system tray, and allow me to configure Windows 7's handling of the UPS?
