Windows 7: IRQ Conflict - Firewire sound card problem
01 Apr 2011   #1
w0mp
Hi, I have Sony VAIO VPCF13Z8E/BI Notebook and my Firewire Sound Card (M-Audio Firewire Solo) does not work properly. I made some search and I think it's about the IRQ assignment. If you look at the picture I uploaded, you can see there are too many main devices in the same IRQ. When I disable the Wireless Adapter, my Firewire device works properly but this is not even a good solution and I couldn't find another way to handle it. If you help me with this, I'll be appreciated. Thanks.
07 Apr 2011   #2
CBAudio
Windows 7 64 bit
I have the same latop for a week now, and the same problems wit MOTU traveler and 8PRE connected via the Fire Wire connector. I tried another fire wire driver but no success.
Disabling the wireless adapter gives proper results indeed, but the screen is refreshed slowly if 16 channels are recorded in parallel. (Audition3)
Anyone know how to change the IRQ settings?
My device properties menu is wiped to gray, and cannot be changed.
CBAudio Experience
Sound card and video card conflict, only on w7
First of all, hello! I have kind of a big problem here. I have an nVidia Geforce GT220 video card and a Creative SB Audigy SE sound card (PCI) They both work fine under windows XP, however, on windows 7 I have a problem with a conflict. The thing is, the video card has integrated Audio (for HDMI)...
Drivers
Sound problem perrsists even after new sound card
As some of you might remember, a few weeks ago I had a problem with sound after I built a new PC and kept my old Win 7 installation using sysprep: http://www.sevenforums.com/sound-audio/280175-onboard-sound-issue-new-pc-build-2.html#post2308990. The problem was that the volume levels were off, and...
firewire pcie card causing BSOD's
Hello, i have a texas instruments firewire pcie card. everytime i run anything through it i get a bluescreen saying: IRQL_NOT_LESS_OR_EQUAL ohci 1394.sys what to do? this is a brand new pcie card
BSOD Help and Support
Need help finding a driver for my PCI Firewire/USB card
hello! I need some more firewire ports, so i thought of this one BELKIN IEEE 1394 PCI CARD 6PIN W/VIDEO STUDIO 5.0 IN (F5U502EA) Will this be compatible with my current setup? I mainly use my computer for making music. My computer (Sandra report): Processor Model : AMD...
Drivers
Firewire card
Hi everyone. I need to buy a 1394 firewire card for my Inspiron 560. I want to transfer recordings from my dvr to my computer. I am not knowledgable about the wirefire technology. My dvr-Cisco RNG200-- has a two firewire ports that are activated. Any assistance will be appreciated. ...
Hardware & Devices
Firewire 800 Card Recommendations
I am looking for a firewire 800 add-on card for my current system. I'm not looking for "budget" or "cheap," I just want something very reliable and robust for Windows 7 x64 (and Vista x64). What firewire 800 cards have you all found to work well in Windows 7 x64 and Vista x64 (both are Home...
Hardware & Devices
