DVD drive not working or showing up in explorer. Help!
I bought a M1530 on the cheap a few months and installed Win 7 x64 with a lot of research primarily from here. Everything worked perfect. The drive is a Teac DVW28SLC. It's a slot load and the only eject button is with volume and DVD controls above the keyboard. I needed to burn something to DVD. I decided to try Imgburn for the software. Installed it, popped a fresh DVD-R in. DVD drive recognized the blank. I usually reboot a computer before burning, realized I didn't so I rebooted. Now, the drive no longer works.
After the reboot:
-Drive is visible to bios.
-Drive cycles on boot up, checking for a disc.
-Drive is not visible in explorer
-Drive is not visible to diskmgmt.msc
-Drive is visible, not disabled and properly installed in the device manager.
-Card reader also seems to not be visible either but is showing up in device manager.
-Disc will not eject from keyboard button.
Things I've tried to fix it:
-Several reboots.
-Uninstall Imgburn.
-Uninstall Daemon Tools Lite.
-Uninstall Drive in Device Manager, then reboot.
-Uninstall Drive and ATA controllers then reboot.
-Delete upper and lower filers at HKLM\SYSTEM\CurrentCOntrol Set\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}, no entries were present.
-Reinstall chipset drivers, though I don't think Intel installer changed or installed anything.
-Fixit does not work.
Anyways, anyone got any ideas? Am I incorrect in diagnosing this as a operating system problem? I need my DVD drive back. Help!
