SATA power sockets
ICIT2LOL
Confusion Therapist
8:43 PM
Central West NSW
Have a new build with a Corsair HX 650 (superb device from every respect) and need to connect two 120 extra fans.
Now I don't want to us the two foot long SATA to Molex cable because it would untidy if not hazardous lying around in the case.
I can get a SATA to Molex adaptor then plug a fan lead (with a splitter) into it to drive the two fans from that one adaptor and I cannot find out if the SATA outlet will drive the two 120 fans.
Will I have enough grunt from the one SATA outlet to drive the two fans as the SATA cables for the drives I can see can have up to four drives on one cable if one so wished.
Have contacted Corsair and to cut a very long story short - am none the wiser.
Otherwise it means using two SATA outlets hence double the other components to do what I want to do.
1920x1080 D1 & D2 & Laptop 1
Desk1 Samsung 120GB 830 SSD
Asus ROG 256GB 850 Pro SSD
Desk2 Samsung 840 256 SSD
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
Yes, Sata to Molex & Y-splitter
on motherboard
6 pata Ide HD's & 2 Sata HD's
All Generic Full Towers
Fast Cable InterNet
Linked via TeamViewer !
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
I have been able to power sometimes 4 HDs & 2 - 80mm case fans from daisy chaining Y-splitters. I would think the 120mm fans would draw less than HDs.
What is your PSU rated at ?
on motherboard
Fast Cable InterNet
on motherboard
Fast Cable InterNet
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
Doc
Thanks for that mate just worked out one SATA had drive is approx 24 watts so I can work it out from there then find the output rating per SATA socket and well see how the fans fair.
Thanks so much for your time and patience.
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
I think your 650w should be fine. I just did a calc with 4 HDs, 1 video card 16gb ram, 2- 120 fans, etc needed 332w minimum :)
on motherboard
Fast Cable InterNet
Doc
Yeh mate just done a quick calc too on those fans (0.3 A) and I'm only looking at 3.6 watts - 5 watts tops for each fan and if those SATA outlets can't handle that well I be a bit surprised eh? lol!!
Thanks anyway your'e a pal!
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
