Best way to test SD Card speed/bandwidth
OldDogEyes
12:45 AM
Howdy,
I'm wondering if there are any way to test the speed/bandwidth of an SD card with built-in Windows 7 utilities/diagnostic software?
And in the absence of that, what are the best (and safest) freeware utilities to do this test?
I'm not having a problem with my machine, simply want to figure out which of my SD cards are the slowest and fastest so I can decide which to use and when.
Many thanks!
Doug
Win 7 Home Premium 64-bitAMD Phenom 9550 Quad 2.20 ghz8gbNVIDIA GeForce 9300 GE
Desktop - HP m9517c
stock
8gb
HP w2558hc (25.5")
1 TB - ST310003-33AS SCSI
16 mpbs - Comcast
Browser: Firefox 3.6.7 as of this writing
Howdy,
Many thanks!
Doug
Hi OldDogEyes, I have used this little app in the past to verify if a pen drive was genuine It will also tell you the transfer read/write rates H2testw - Fix Your USB! ;) If you have a usb adaptor for your SD card it should work on that
win 7 ultimate32bit, Win8.1pro wmc 32bitamd phenom x4 9600corsair twinxs 2x2gb2x nvidia 1gb 8500gt
self build
amd phenom x4 9600
asus m2n32-sli deluxe
onboard
23" PB Viseo 233d
maxtor sata 500gb
maxtor sata 320gb
fujitsu sata200gb
oryxx tornado 750w
thermaltake xaser lll
artic freezer64 pro + 7 case fans
If you are using Win7 or Vista, make a file at about 500 mb in size, or find any large file. Copy it in to a new folder for testing. Open the folder that is the SD card root directory. Copy the file accross from the folder on the hard disk to the SD card root. While copying, look at the details in the copy notice window. Down toward the bottom it will display the mb/sec of copy speed.
Jerry G.
Windows XP Will Soon be Windows 7
