Strange External Drive Problem
I’m having a strange problem with an external hard drive. I have two of the same model drive and one of them has a problem. I will refer to them as drive #1 (good) and drive #2 (problem). The drives are 1TB, USB3. My PCs are running Windows 7 and they all have USB 3.0 ports.
I have one of these drives connected to my main PC at all times but only one of them at a time - never both at the same time.
Drive #1 always works perfectly.
When I try to write to drive #2, 90% of the time it “stalls” for as much as a minute before it starts writing. (10% of the time it works normally.) This happens whether I manually copy a file to it using Windows Explorer or use a program to save files to it. It just stalls but most of the time it eventually un-stalls and writes.
This is what I have tried so far:
1. Tried drive #2 on two other PCs. Same problem with both other PCs.
2. Tried drive #2 with different cables and different USB3 ports. Same problem with all.
3. Checked Windows 7 security settings. All OK and all are set the same for both drives. I also checked the various properties settings for the drives and everything looks correct there. I also checked for an updated driver and I already have the latest. I also have all of the latest updates for Windows 7.
4. Tried drive #2 (which is USB3) on a USB2 port. Same problem.
5. Re-formatted drive #2 and started from scratch. The problem remains.
6. Contacted the manufacturer (LaCie) and tried everything they suggested. The problem remains and they have no additional clues.
7. I returned drive #2 and ordered another one of the same model from a different vendor. The replacement has the same problem.
8. I returned the replacement and ordered another replacement from the manufacturer (LaCie). The second replacement has the same problem.
All this time drive #1 continues to work perfectly. Again, both drives are the same model.
I’m baffled by this one. Any clues appreciated.
Thanks.
Peter
