Mic Quality problem
  1. Posts : 8
    windows 7
    Mic Quality problem
    Hi all, my mic works fine on Skype. It sounds loud and clear on Skype but when I am trying it on Voice Recorder and from the sound options in Control Panel it is very low when I play it back. I have the Microphone and Boost slider set all the way. And I have the sliders set up all the way on VIA HD Audio Deck(recently updated). Is there something I am missing? Thanks.
  2. Posts : 1,996
    Windows 7 Home Premium 64 bit
    Check your VIA HD Audio Deck for the Playback Volume.
  3. Posts : 8
    windows 7
    It doesn't say "Playback" anywhere on the VIA HD Audio Deck for Microphones, it just shows:
    REC Vol
    Speaker Output
    REC Vol
    Speaker Output
    DB
    They are all the way up.
    It's strange to me that it works absolutely fine on Skype, I checked the settings on there and they are max but so are the settings in my control panel but it doesn't give the same results.
  4. Posts : 8
    windows 7
    Update windows, still no dice, any help please?
