CPU temperatures problems
Page 2 of 4 FirstFirst 1234 LastLast
  1. Posts : 50
    Windows 7 Home Premium SP1 32 bit
    Hi guys !
    Thanks for your replies again :)
    @spinifex
    Look at Stormy13's Pic, looks like i cant add a fan in the front pulling in air, unless sandman can do us a favor and post his modified case pic :P, also i will see if i can go to a technician and give a the pc a good clean and thermal paste change.
    @stormy13
    Hmm its a possibility... I will open the case and see if the PSU case is facing the GPU and where it is pulling air, i will post again when i do it :)
    @sandman
    Can you post your modified case pic please ? (inside and outside :) )
    @Layback Bear
    Well right now i count with.. like 70$ ? i can get some more i think :P, but i want to add some cooling fans, since its kinda cheap, also remember than i live in Colombia, and electronic supplies are more expensive and hard to get.
    Oh btw people the temperature in my city is about 27-31 Celcius during the day and like 24 during the night :P with high humidity, in case this helps a bit..
    Juan.
  2. Posts : 1,364
    Win7 Ultimate x64
       #12
    @stormy13, now i have seen the case, i understand the problem.
    @Layback Bear, a more suitable case is the way to go for sure, pending affordability.:)
    @Chronox, looks like you have a bit of a challenge ahead. Good luck mate.
  3. Posts : 6,879
    Win 7 Ultimate x64
    Juan no idea what it would go for or if even available, but if you decide to go the new case route something like this,
    Newegg.com - COOLER MASTER Elite 330 RC-330-KKN1-GP Black SECC ATX Mid Tower Computer Case
    wold provide lots of room and good cooling properties over that HP case.
  4. Posts : 50
       #14
    Looks pretty neat, thanks stormy..
    Any cooling system recomendations you can give me ?
    Thx, Juan !
  5. Posts : 1,364
    Win7 Ultimate x64
       #15
    Juan, if cost is prohibitive, there are case/fan mods you can do.
    I realise the pics i am posting are not of the same case, but it's to give you food for thought.
    These are some i have done over the years.
    Put a bigger fan on the heatsink, by using an adaptor.
    Cut the grating out for better airflow.
    Cut some holes in the side cover and added a couple of fans.
    Attached Thumbnails Attached Thumbnails CPU temperatures problems-imgp0620.jpg   CPU temperatures problems-imgp0899.jpg   CPU temperatures problems-imgp1025.jpg
  6. mjf
    Windows 7x64 Home Premium SP1
       #16
    My temporary (sort of permanent) solution to my overcrowded ACER case is to leave the side off and use a small personal fan (4 inch blades) blowing air into the side. I use it on warm days and when video encoding for hours.
    It might not look pretty but VERY effective. The fan cost me $10.
    My Quad Intel Q8300 runs 100% for hours not exceeding 50 Celsius core temps.
    My HDD is kept very cool as well.
    PS: my next computer will be custom built with heaps of cooling.
  7. Posts : 33
    Is this your case? HP Pavilion a6532f Athlon 64 X2 5200+ 2.7GHz 3GB 500GB DVD±RW DL Vista Home Premium - Open Box a6532f KT374AA
    looks like you could cut a hole in front of case and add a 120mm fan.
    It also looks like a btx form factor- and prior case suggestions wont fit.
    The front cover should come off in one piece, usually by pushing some tabs-
    The case itself may even have a fan mount- if not cut a hole and drill 4 screw holes for a new fan- pretty doesnt count as you will also be reworking the front cover- get a blue fan and will look great-
    Also looks like the hdd is mounted vertical- maybe you could move it up to a 5.25 (cd rom) bay with an adapter-
    Cut the front cover too- The fan needs to breath both in and out- get or make a ring bigger than the hole for the fan- cover it with a black nylon (glue material to ring), tape the new hole hider/filter over the hole and clean every month or so.
    By black nylon I mean steal a pair of black nylons from your wife or girlfriend...
    ___________________________________________________________________
    Also since fans and labor are cheap maybe buy an after market cooler as that one looks like a piece of cr&p.
    Post some pictures for us both before and after
    Bill
  8. Posts : 25,847
       #18
    Correct, install more fans would be cheaper if you can. The Corsair 600T will be my next case. It might be a little over what you want to spend. It is about $150.00. Go online and watch some videos on it before you say no. Both a good power supply and case will allow you to expand in the future. Their for you won't have to go through this again. I have never owned a case that I didn't add fans. So a case that will allow you to do that is a great choice. Check out the Google.
    Google
  9. Posts : 1,364
    Win7 Ultimate x64
       #19
    Bill
    An alternative to black nylon, so you won't upset your girlfriend/wife, is to buy/make something like this. Less chance of cutting your fingers and changing the suggested blue fan, red.
  10. Posts : 33
    Nice-one of those would look even better with the blue fan (just get one with a filter too, or filters can be added underneath any of the covers)
