Cooler Master SATA power cables
Page 2 of 2 FirstFirst 12
  1. Posts : 578
    Windows 7 Pro x64
    magnetite said:
    I did phone up the place I bought the computer from and they said they couldn't find any power supply box.
    CM Store
    That is the power supply cable. Now normally it's $3.99, however, when you add up the shipping, it's around $18 or so. Most places I've shopped at online, the shipping is usually cheaper than the item itself.
    So you bought this computer from a store that builds PCs. Right?
    What they did was keep the other cables that were not need to build your unit, not used at the time they built it.
    I'd take a run over there, if it's fairly local, and ask for the cables.
  2. Posts : 93
    Windows 10 Pro 64-bit
       #12
    I'll look into it.
  3. Posts : 1,996
    Windows 7 Home Premium 64 bit
    Oh, I see you didn't buy a retail power supply, but you had your PC built through a third party. If that's the case, then that's a different situation, as they may have used bulk parts. They may buy bulk or oem parts from Cooler Master, which will not include all the parts that you get in a retail box.
