Battery problem
  1. Posts : 4
    xp
    Battery problem
    I replaced my dell battery. All volts ect were exactly the same. Worked fine for a month or so. Now the indicator says bat has 100% charge (if I remove bat the indicator says “no battery, reinstall and says 100% charge) but when I remove power cord computer does not work on battery.
  2. Posts : 116
    Windows 7 Professional x64 Sp1
    Welcome to SF
    What model computer do you have?
    This will help in the diagnostics.
  3. Posts : 4
    xp
    Dell Latitude D600
    Thank you,
    It is a Dell Latitude D600
  4. Posts : 116
    does the batterie have one of the following serial numbers
    1K055
    C5446
    F2100
    KD494
    W5915
    Y1333
    3K590
    C6269
    F5132
    OR331
    X5308
    Y4500
    5P474
    C6270
    GD785 M3006 X5329
    Y5466
    6P922
    D2961
    H3191
    RD857 X5332 OU091*
    C2603 D5555 J1524 TD349
    X5333
    W1436*
    C5339
    D6024
    JD616
    U5867
    X5875
    C5340 D6025 JD617
    U5882
    X5877
  5. Posts : 116
    heres where the number is
    Attached Thumbnails Attached Thumbnails Battery problem-barcodecirclespurple.gif
  6. Posts : 4
    xp
    I don’t think so.
    There are 2 bar codes with #’s under them.
    LP0210062401M002278
    100623003
    model # DL1194L7
  7. Posts : 116
    Ok because the serial numbers that were above were recaled by dell so you would just get a new one.
    Do you have the drivers and programs disk that came with the computer because it has a diagnostic tool that allows you to check your battery and it will run a series of tests.
    If you have the disk insert it and shut down then when you turn it on hold the C key and it will boot into the diagnostic program to check for battery life
  8. Posts : 4
    xp
    Unfortunately I don’t have any disc. I bought this used a couple years ago.
