Windows 7: Hard drive has 5 parts to it in device manager
09 May 2011   #21
windows 7
Quote   Quote: Originally Posted by marsmimar View Post
Quote   Quote: Originally Posted by hollyoaks777 View Post
I have just done reinstall and formatted my hard drive and its the same lol be up all night reinstalling my progams lol
If I may make a suggestion? In an effort to avoid similar problems in the future, once you have your 1545 configured the way you want with all programs, apps, etc installed, invest in a new external hard drive. Here in the Colonies they're selling 2TB drives for under $100 US.
Seagate ST320005EXA101 2TB Expansion External Drive - 2TB, USB 2.0 at
Make a system image of your computer and store it on the external HD. Leave the original system image intact and make a new image every week or so. If you ever have to reinstall everything again, restore from the system image of your choice and be back online in about 30 minutes. The original image can be your "master clean install" to avoid the dreaded up-all-night headache. You can use the built-in 7 backup utility or the free Macrium Reflect or Paragon. There are others (paid and free) but these are the ones I've used.
Backup Complete Computer - Create an Image Backup
Imaging with free Macrium
Free Backup Software: Paragon Backup & Recovery (Advanced) Free Edition - Overview
And i wont have to install serial numbers for products again i take it. If so that would be great
09 May 2011   #22
windows 7
Quote   Quote: Originally Posted by sygnus21 View Post
Quote   Quote: Originally Posted by seekermeister View Post
Those channels are not your hard drive, it is controllers:
IDE/ATA Channels and Resource Usage
Exactly +1
Attachment 153408
BTW If I wasn't using AHCI in the BIOS I would also have more then two ATA channels shown.
thanks mate
Search this Thread:
Advanced Search
WD SES Device USB Device driver not found from old internal hard drive
I have an old Western Digital drive that came with Dell Inspiron One 2305 and replaced it after 5 years. There are some files I need from it now and I'm trying to connect via usb to sata. The WD volume does not show up. I got to device manager and found it listed in in unknown devices and it needs...
Hardware & Devices
EEE pc windows 7 starter to many hard drive parts
hi i have i eee pc i have noticed that my C: drive is only 99.9 gb and the Recovery D: is 122gb and empty i know this is not right but how doi fix it i am running out of space on my C::cry: in disk manigment it says 232.88 gb with 4 diferent partitions only 2 named how can i fix this with no...
Hardware & Devices
Hard Drive shows in device manager, not My Computer
I've spent most of the night searching and cannot seem to find an answer to my problem so I registered with the hopes that someone here may be able to help. I have a NAS set up with two 2TB Samsung Spinpoint hard drives. The hard drives in the NAS were partitioned to have 300GB in a RAID 1 and...
Hardware & Devices
1TB WD USB hard drive failure - is in Device Manager, not initialized
Hi. I was normally using my computer, when I suddenly noticed one of my hard drives disappeared from My Computer. Checked the Device Manager, I get the following. Trying to initialize it throws up this error: Seems to spin just fine. Trying...
Hardware & Devices
cant see hard drives in disk management or in device manager.
hi few days back i have completely formated my hard disk with the help of seagate seatool.Then i have installed windows xp sp3. i have made 4 partitions at that time ie. c,d,e,f. After that i have installed windows 7 now i cant see my hdd in disk management or in device manager. both device...
Hardware & Devices
Hard drive hidden in disk/device manager
Hi. I tryed to make a system back up but it keeps failing with error code0x80070002) (windows cant find a backup device) went into disk manager and found that my external hard drive that I had plugged in to make the backup on was present and working fine, the strange thing was that i couldnt see my...
Hardware & Devices
