Small problem
  1. Posts : 21,004
    Small problem
    Have fitted a Seagate Barracuda 500GB ST3500413AS in addition to my Samsung 103j Spinpoint as it from new (6 weeks) has been noisy.
    Howvere I have put in the Seagate but it isn't showing on my Computer readout as anything - anything I've done wrong?
    The board is Gigabyte h67A-UD3H-B3 and I've plugged it into the SATA3 _1 socket as it is 6Gbs device and all the other SATA 2's are taken up.
    It's spinning because I can feel it but why no reference to it??
  2. Posts : 12,012
    What is "my computer readout"????
    Does it show in Disk Management? You may have to rescan your drives in Disk Management and assign a drive letter to it there.
  3. Posts : 21,004
    Hiyya ignazatsonic
    Just clicking i "Computer" where it shows the drives etc and a couple of pics of Device manager in control panel.
    I can see n reference to brand or size.
    Attached Thumbnails Attached Thumbnails Small problem-capturenewdissk1.png   Small problem-capturenewdisk2.png
  4. Posts : 12,012
    I wouldn't worry about it.
    My comparable "devices" list shows only 3 items: mouse, monitor, PC. Nothing at all about drives, keyboards, etc.
  5. Posts : 1,800
    Windows 7 Pro x64 SP1
    A brand new hard disk normally won't show in my computer unless it has been partitioned and formatted.
    Right click on my computer and select computer management and then go to disk management and
    partition the drive. If it does not show there, then you might not have it connected correctly or
    you bios is not sensing the drive.
    Rich
  6. Posts : 21,004
    A LEGEND
    Richnrockville you are a legend it was too easy and I was getting all sorts of suggestion , hints etc.
    Can' thank you enough that should be a tutorial for dopes like me (unless there already is one *looking furtively around*.
    Jeez mate I ma so pleased I could errrrr turn my pants a diferent colour it's the first thing in a few days that gone right haven't got a cure forthe flu have you lol!!
    John
  7. Posts : 6,879
    Win 7 Ultimate x64
    Don't know about a cure, but a hot toddy or two has been known to make the symptoms much more bearable.
  8. Posts : 3,427
    "To Alcohol! The cause, and solution to, all of life's problems" - Homer Simpson
  9. Posts : 21,004
    Hiyya stormy
    Now the cure sounds fabulous but mate the devils brew eats holes in my stomach these days so - or else I would!!
