HD crush uttorent problem .
  1. Posts : 3
    windows 7 ultimate 32BIt
    hi
    installed new WD 500Gb SATA
    i moved 60GB from local disk to the new with no problem
    BUT
    when i downloaded from uttorent after 20min it crush my drive and i had
    to reconnect it again from the motherboard
    is it network/anti virus/hard disk problem?
    i was thinkg about cache maybe...but im not sure....its really annoying .
    i have 2800 AMD proccesor 2 GB ram .win7 ultimate 32 bit +nod32 .
  2. NoN
    You could try to:
    Write-Caching - Enable or Disable
    If you're wired powered and have an UPS backup it should be fine enough.
    And also some Optimization here:
    Optimize Windows 7
    Reset your client uTorrent to it's default value.
    Don't enable (set to "Disable Windows Caching in uTorrent, write & read") in the client, but enable it in windows 7.
    Forgot to tell that maybe you should update the controller drivers...S-ATA AHCI if needed.
    Attached Thumbnails Attached Thumbnails HD crush uttorent problem .-capture.png
  3. Posts : 3
    10x- currently not near my pc...ill try it today and update you
    thanks man
