Trouble formatting secondary drive.
  1. Posts : 2
    win7 x64
    I just placed an old hard drive into my computer to use as a slave. After I booted up on my current hard drive I went into disk manager and tried to format all the partitions. I formated one easily but the other won't seem to format. The option to format or delete volume are both greyed out.
    I then tried to boot from my win7 disk to format the drive that way but it said it could not format dymanic drives. I can't change the drive to basic without deleting the last simple volume.
    I'm stumped on what I should to do to make this work. Any suggestions and/or help is greatly appreciated.
    Thanks.
  2. Posts : 16,163
    7 X64
    Use diskpart clean command - make sure you are pointing at the correct drive.
    From an elevated command
    diskpart
    lis disk
    sel disk #
    clean
    exi
    make sure you use the correct disk number in place of # above.
      My Computers
  3. Posts : 2
    win7 x64
    I tried that as well. It said: Clean is not allowed on the disk containing the current boot, system, pagefile, crashdump or hibernation volume. I don't understand how that is so if I'm booted on the other hard drive.
    EDIT: I managed to use the cmd clean prompt by running my cmd before actual boot. This allowed me to wipe my secondary drive even with all the other errors I was previously getting while trying to do it during windows.
  4. Posts : 16,163
    7 X64
    Glad you got it working - thanks for the update.:)
      My Computers
