animemaster2011
- Local time
- 11:23 AM
- Messages
- 8
Hi all,
I'm not sure if this is in the correct forum or not, but I'm having an issue with my system.
It's not saving startup/recovery settings (when changing it to small dump instead of kernel) not sure if this is normal or not. Another problem is a bluetooth settings problem, Everytime i try to add a device, it never detects my item, just hangs on the "searching for devices screen, and the receive files dialog says "invalid argument supplied" Any idea what is going on? Oh also the bluetooth devices window doesn't load either, just hangs as well.
Windows 7 Ultimate x64Intel Core 2 Duo4 GB DDR2nVidia GeForce 9600M GT
- HP HDX X16 1140US
- Windows 7 Ultimate x64
- Intel Core 2 Duo
- 4 GB DDR2
- Graphics Card(s)
- nVidia GeForce 9600M GT
- Screen Resolution
- 1366 x 768 (max)
