Plz help, monitor randomly shuts off/system still on
Page 2 of 6 FirstFirst 1234 ... LastLast
  1. Posts : 24
    Windows 7 Ultimate X64
    ran it for 3 hours, passed everything...
    its still running now, will it give me a stress test report when its done or do i just need to turn if off?
  2. Posts : 1,496
    7 Ultimate x64
       #12
    You just turn it off.
    Not sure what to suggest. G92's had a lot of heat related issues. Can you take the side panel off your case and make sure the fan is spinning on the card?
    Something is making the monitor turn off... and since you've tried 2 working monitors and Primed for a few hours, everything points to the card. Either it's overheating or it's dying. Let's hope for overheating.
  3. Posts : 24
    ya, i did and u have it off atm and the fan is spinning... unfortunately that doesn't help much... im sending the card back to the manufacturer for testing hopefully that helps
  4. Posts : 24,479
    Windows 7 Ultimate X64 SP1
       #14
    A shot in the dark, pull the graphics card out and re-seat it, sometime they can get a bit loose. If there is another available slot for it, try that too.
    The latest nVIDIA driver
  5. Posts : 24,479
       #15
    With the graphics card out, make sure it is not full of dust. This caused another user's monitor to shut off due to over heating.
  6. Posts : 24
       #16
    did that already took it out 4 times at thi point and blew it out like no tomorrow... and while there is a different slot on my motherboard for it... it wont fit there, also i got the newest drivers
  7. Posts : 1,496
    7 Ultimate x64
       #17
    What's your board's make and model number?
  8. Posts : 24
       #18
    MSI K9N2 Diamond Motherboard - NVIDIA nForce 780a SLI, Socket AM2+/AM2, ATX, Audio, PCI Express 2.0, Dual Gigabit LAN, USB 2.0, Firewire, eSATA, RAID, HDMI support
    MSI K9N2 Diamond Motherboard - NVIDIA nForce 780a SLI, Socket AM2+/AM2, ATX, Audio, PCI Express 2.0, Dual Gigabit LAN, USB 2.0, Firewire, eSATA, RAID, HDMI support at TigerDirect.com
  9. Posts : 1,496
    7 Ultimate x64
       #19
    I don't understand why you can't "fit" the card into another pci-e slot... that board has 3 pci-e 16x slots. 2 are free right now?
  10. Posts : 24,479
       #20
    Your video driver is 275.33, 05/20/2011, then?
    you might have a look at your advanced power setting and make sure the monitor isn't set to shut down.
