Plz help, monitor randomly shuts off/system still on
Page 4 of 6 FirstFirst ... 23456 LastLast
  1. Posts : 24
    Windows 7 Ultimate X64
       #31
    it should be under warranty still, by the way would i be able to use " Galaxy NVIDIA GeForce 9500 GT 1GB PCI-E 2.0 SLI"
    or what cards can i get my my motherboard? or any cards you would recomend that are afortable and compatible with my motherboard?
  2. Posts : 1,496
    7 Ultimate x64
       #32
    Yes, you can use a 9500GT, but why on earth would you? That's a downgrade from your current card, which is already old... the 9500 would be worse.
    You can have your pick of any PCI-express card made.
    "Affordable" is a relative term. What's your budget?
  3. Posts : 24,479
    Windows 7 Ultimate X64 SP1
       #33
    That card or any PCI-e X16 card will work provide you have the room AND any needed power cables for it.
    Do you guys stay up all night?:)
    Some random thoughts...if the card was being over-worked, wouldn't the whole system shut down or BSOD? Check the games you play most often and see what the minimum hardware requirements are, sisnce LoL (?) plays.
    Any card here would work, limited by your budget and power connectors. Fumz is correct, the 9500 is about 2 steps backwards.
  4. Posts : 276
    HP Win7 Pro x64 | Custom Win7 Pro x64
       #34
    Also consider the possibility that it could be the power supply.
    Download and run this: CPUID - System & hardware benchmark, monitoring, reporting
    Let it run, play a game for just about 5-10 minutes, then exit, if it crashes do it again the same, see what temps you hit. Post this info back here, with a screenshot.
    It could easily be a rail giving out on the psu, good to test this before you spend any money.
  5. Posts : 24,479
       #35
    Yup, works for me. Actual shot of CPUID HW monitor.
    Plz help, monitor randomly shuts off/system still on-capture.png
  6. Posts : 24
       #36
    This is a screen shot after 10 minutes
    Attached Thumbnails Attached Thumbnails Plz help, monitor randomly shuts off/system still on-hm.png
  7. Posts : 24,479
       #37
    Your graphics card is very hot! did you check you game specs?
  8. Posts : 24
       #38
    about 30 min
    Attached Thumbnails Attached Thumbnails Plz help, monitor randomly shuts off/system still on-hm30.png
  9. Posts : 24
       #39
    ya, its counter-strike its a game from like 2001, and practically any computer should be able to play it, but here the specs for it
    • Minimum: 1.7 GHz Processor, 512MB RAM, DirectX® 8.1 level Graphics Card (Requires support for SSE), Windows® 7 (32/64-bit)/Vista/XP, Mouse, Keyboard, Internet Connection
      Recommended: Pentium 4 processor (3.0GHz, or better), 1GB RAM, DirectX® 9 level Graphics Card, Windows® 7 (32/64-bit)/Vista/XP, Mouse, Keyboard, Internet Connection
  10. Posts : 24,479
       #40
    You might try the driver reinstall again, First uninstall you current driver, have the new one on your PC ready to install. Use Revo Uninstaller.
