My dvd drive won't work?
  1. Posts : 6
    windows 7
    i have a TS-L633A SCSI dvd drive.
    when i insert a cd or dvd its won't read it. it will eject it and say to insert a cd. what is the problem.
    I have tried to uninstall and reinstall, i have tried removing the upper and lower filters.
    what is the problem?
  2. Posts : 8,476
    Windows® 8 Pro (64-bit)
    hi brandon, i guess your dvd drive firmware needs to be upgraded.
    if you are facing this issue since recently, try a system restore.
  3. Posts : 6
    windows 7
    thanks ill give it a try.
    and this started when about a week or 2 ago.
  4. Posts : 8,476
    try the firmware update. If it doesnt work, probably do a system restore. Let us know the results.
  5. Posts : 7,878
    Sometimes these drives just die. Don't forget that. It's possible that it's just crapped out and replacement might be the only option.
  6. Posts : 47
    Windows 7 Professional x64 (MSDN)
    Also, have you adjusted BIOS settings for it? My DVD drive functions very differently under AHCI/Raid and "Native IDE" modes.
  7. Posts : 6
    windows 7
    the firmware said that it is not compatible with the selected drive.
  8. Posts : 6
    windows 7
    ok well i kinda suck at computers so can u explain how i can do that.
    and well i got this laptop about a month ago.
  9. Posts : 47
    If you don't know where to find the BIOS options, it's highly unlikely you would have changed a setting that would be causing problem For future reference though, you can access the BIOS by pressing a key when you first turn it on. On my computer it is the delete key, and it can be many others (F1, F2, F5, F10, Enter are a few other examples I've seen)
  10. Posts : 6
    windows 7
    ok thx.
    yeah i have tried a system restore and still wont work
