External Sata drive will not keep assigned drive letter
Terrym
3:12 AM
Atlanta, GA
I am running Windows 7 Pro. Have a external dual dock connected to a estata port. One of the drives assigned letter K often comes up as E and I have to change as application is looking for K. Another disk in this dock works fine. No problems.
Does anyone know why this might be happening or anyway to prevent?
Seems like when I go to disk management and assign K it should stay that way.
Winows 7 Pro, 64 bitIntel i7 92012 GBNividia GeForce 9800 GT
System Built by me
Intel i7 920
ASUS P6T
12 GB
Mother board
HP vf 17
1- 300 GB Western Digital raptor 10,000 rpm
2- 640 GB WD
1- 500 GB WD
12 MB Cable
Try assigning a drive letter a "distance" away from your existing drive letters.
For example, change the dock drive letter to Z and see how you get on with that.
HP Pavilion Elite 495UK
Windows 7 Ultimate SP1 64-Bit
Intel Core i7 870 @ 2.93GHz
MSI 2A9C (CPU1)
HP2310i
460W
HP Elite
Air cooled
Logitech Wireless M180 mouse
2Mb
That's good advice from seavixen. Windows has a letter assigned to each port. Sometimes, whatever drive letter you assign-Windows will use the drive letter of that port instead. I have an eSATA dock and run 4 drives in that dock. I assigned them letters W,X,Y,Z. I have had no issues. Whichever drive I put in the dock is recognized as the correct drive.
    ALWAYS UNDER CONSTRUCTION
    Windows 11 Pro
    Ryzen 9 5900X
    Asus X570 Crosshair Viii Hero
    32GB G Skill DDR4-3600
    EVGA RTX 3080 FTW 3 Ultra
    3 X Asus 27"
    2 X 1 TB NVME drives
    EVGA 850
    Phanteks Eclipse P400A
    EVGA 280 AIO
    Logitech G510s/ Logitech G13
    Logitech G502
    ESET/MBAM Pro/SAS Pro
    Chrome/ Firefox/ Edge
    Dell 16 Plus
    Windows 11 Pro
    Intel Ultra 9 288V
    32 GB LPDDR5X 8533
    2560X1600
    1 TB NVME
Sounds good. I will try that and let you know the results. Thanks.
System Built by me
Intel i7 920
ASUS P6T
12 GB
Mother board
HP vf 17
2- 640 GB WD
1- 500 GB WD
12 MB Cable
You're very welcome. I hope it does the trick for you.
MSI 2A9C (CPU1)
HP2310i
460W
HP Elite
Air cooled
2Mb
So far so good
Changed them to y and z and do far it seems to be working. Thanks.
System Built by me
Intel i7 920
ASUS P6T
12 GB
Mother board
HP vf 17
2- 640 GB WD
1- 500 GB WD
12 MB Cable
You are welcome. I hope it continues to work well.
    Windows 11 Pro
    Ryzen 9 5900X
    3 X Asus 27"
    EVGA 850
    EVGA 280 AIO
    Logitech G502
    Dell 16 Plus
    Windows 11 Pro
    Intel Ultra 9 288V
    32 GB LPDDR5X 8533
    2560X1600
    1 TB NVME
