Need Help With Power Supply
AEZero
2:48 AM
Right now I am getting ready to buy a HIS IceQ H567Q1GD Radeon HD 5670 and I need help getting a decent power supply for it. I was thinking about getting a CORSAIR Builder Series CX430 because that's all I can really afford for this rig right now. Is this a good power supply that can last me at least a good year until I can get enough money to get a better one? If not any suggestions of a PSU under $50.00 would be nice. Thanks :)
That card recommends a minimum 400 watt power supply. The 430 makes it but you are cutting it close.
I believe you should have some "overhead" for a power supply to avoid any issues. Usually 50% more than needed. Power supplies lose output as they get older and you might add extra devices in the future.
You can use a power supply load calculator, available on most manufacturer's web sites (like Antec) to determine your approximate maximum usage. If the 430 meets the limit and it is all you can afford than it is a small risk.
But a 600 watt or better would be a safer solution.
Home Built - Jan 2013
i7-3820
Asus P9X79-PRO - Bios 4608
GSkill F3-14900CL9Q - 16GB
On board Realtek ALC898
Acer S271HL
#1- Samsung 840 Pro Series
Corsair Obsidian 550D
MS KC-0405
Intellimouse 5-button
56 Mbits/Sec (on a good day)
Avast & Malwarebytes
Asus DVD - DRW-24B1ST 24X
If you can swing the extra 10-15 dollars, I would recommend a basiq 550 or a corsair 500, they are nice power supplies and will give you room to work with.
W7 Professional x64AMD Athlon II X3 445 Rana 3.10 GHzPNY XLR DDR3 1600 4x2GBNVIDIA GeForce GTS 450 (fermi) 1GB GDDR5
Pugh Technologies
W7 Professional x64
MSI 870A-G54
Realtek ALC892 onboard
ASUS VE205t, Viewsonic VX2035WM
1600x900, 1600x1050
977GB Hitachi Hitachi HDS721010CLA332
244GB Western Digital WDC WD2500AAJS-65B4A0
488GB Western Digital WDC WD5000AAJS-00A8B0
488GB Western Digital WDC WD5000AAKS-00UU3A0
Antec EarthWatts EA650 650W
ThermalTake Armor A90 Mid Tower
3x 120mm in, 1x 120mm & 200mm out, self built hydro-cooler
Logitec 55
Razer Deathadder
20 Mbps D/L, 9 Mbps U/L
Thanks! I'll probably just get the corsair CX500
CX 430 Review
Here is a great review on this power supply.
Corsair CX430 Power Supply Review | Hardware Secrets
The CX 430's they are selling now are the x2 version. they also have a review of it.
I have been using the original since last Christmas with a 5770 and an Athlon x2 5600+ and have been very happy with it. (The CPU bottlenecks this card. Upgrading to new MB and x4 965)
windows 7 x 64 ultPhenom II x4 840Corsair XMS3 2x4 GBHIS Radeon 5770
Microsoft
windows 7 x 64 ult
Phenom II x4 840
Gigabyte GA-990FXA-UD3
Corsair XMS3 2x4 GB
HIS Radeon 5770
Realtek onboard
Acer P221w + Samsung T220 HD
1024x768
Various
430w Corsair Builders Series
HP
Freezer 64 Pro v1
Logitech G15 v1 + Belkin n52te SpeedPad
Logitech M570 Wireless Trackball
1000mbs
Extra front intake fan installed in two of my 5.2" bays which blows directly into my Freezer Pro CPU fan. Dropped temp nearly 10c.
