Windows 7: Problem.. Urgent.. help
20 Jul 2011   #21
Microsoft MVP
Windows 7 Ultimate X64 SP1
Hi SinRival, you did good by uninstalling Chrome in my opinion. As was said you were seriously over working the little thing. A netbook is not meant to do much more than email, browsing the net, listen to music. The Atom is not up to all of what you are trying to do. If possible add the extra 1GB of RAM. Video editing is very CPU-intensive and YouTube will tax what little graphics power you have.
I would suspect your crashes are due to over heating with all of the multi-tasking.
Have you tried to update all of your USB devices drivers?
For the spell-checker, ieSpell - Download. When you are replying to a post, in the upper right of the message window, find the "ABC" with a check mark on it. Click it and you will be asked to download ieSpell.
It will work here with posts and when you highlight any text and then right''click on it. There will be a spell check option.
20 Jul 2011   #22
Windows 10 Education 64 bit
Just ran speccy on my daughters netbook. Her Atom processor was running at 43 C right after power up, so your temps look about right to me. You really need to look at your mini dump files etc.
Crash Reports - Read[2]=Performance Maintenance
Dump Files - Configure Windows to Create on BSOD[2]=Performance Maintenance
20 Jul 2011   #23
Microsoft MVP
43C sound hot, but I couldn't find the MAX temp for the Atom, there's a bazillion of them and all I found was TDP's (thermal design power) which were between 1 and 2 watts or so.
21 Jul 2011   #24
Looking up the one "I think" is in my daughters netbook, I see a maximum case temperature of 85.2 c listed. Thats twice what hers is running at. I saw some that went as high as 125 c. 43 c does sound hot, but I really don't know if thats abnormal for a netbook. If it was my desktop I would be opening it up for a look see and a cleaning. I am probably going to follow my own advice and have a go at blowing any dust I can out of her netbook. If there are any other members who wouldn't mind posting their temps for a similar netbook or even laptop to put things in perspective, it would be greatly appreciated.
21 Jul 2011   #25
don't have it in front of me at the time, by my ASUS normally runs in the 30s. I also keep the display only as bright as needed and run on PowerSaver plan. The Asus has an Atom.
07 Aug 2011   #26
Windows 7 Home Premium 64-bit (6.1, Build 7601)
Two Weeks Later/Back from holiday.
I just got back earlier morning and well now it's about 7pm, and it happened again. Black Screen, reboot. Sort of scary, moments ago I plugged my mouse into the left usb port, I'm thinking it might be a bad port but, I don't know.
Wondering what to do so.
07 Aug 2011   #27
Now that you have a BSOD, start a fresh thread, forgetting the past, describing your present problem and following the procedure given there in the Crashes and Debugging forum
Blue Screen of Death (BSOD) Posting Instructions
A suggestion is to fluff out your System Specs. Here's how with programs that are free that will provide info to you.
User CP (3rd item in the top menu bar) |
in left-hand column, under Your Profile, Edit System Spec |
Use Speccy - System Information - Free Download
and/or SIW to gather info for filling in the blanks.
Do me a favor. Please add the word laptop or desktop to the “system manufacturer” block.
Provide full windows version info, such as provided by Speccy:
MS Windows 7 Ultimate 64-bit SP1
Use the “Other Info” block for Optical Reader, Mouse, touchpad, wifi adapter, speakers, monitor
Scroll down and click on the SAVE CHANGES button.
Search this Thread:
Advanced Search
problem in reinstallation of window 7 urgent
hi friends, i have reinstalled window yesterday. when naming of pc completes and other steps like time zone comletes and it countdown for the re start then it ask me the option to boot the pc giving two option of window 7 and again just below of it another window 7 and says press f10 for advance...
Installation & Setup
High CPU Problem. Urgent answer please.
Hello there! I Really will appriciate all who will try to help me. Thing is i checked mostly all forums, tried to do a lot of stuff to get my CPU work better. Now what is wrong with it? My computer(With Windows7) gets so laggy when Physical memory is out(WHERE?) I Can turn off every single...
Performance & Maintenance
Urgent IE9 Problem
Hey, bit of an ameteur here but i've encountered a problem which has pretty much disabled me from doing anything I need to on my computer because of an automatic update from windows (IE9) a few days ago. IE9 installed, and ever since then ive been unable to visit some websites, it loads...
Browsers & Mail
[urgent] Outlook 2010 Problem
i Have Sony Vaio Laptop. Due to some reason my OS is not working, but i have all the files on My hdd intact. i m now booting through HIRENS BOOT CD, but i have lots of IMPORTANT CONTACTS & E-MAIL on OUTLOOK 2010, which is now not accessible. So can anybody pls. tell me how can i get all those...
Browsers & Mail
severe problem,need urgent help!!!
hi... i always got this problem since i bought dell studio 1737.and i searched on web,and noticed that this is more common with dell laptops... i have windows 7 ultimate x64 and when i try to burn windows 7 image on dvd using ultra iso to make a bootable disk,it says DVD R/RW requires settings to...
Hardware & Devices
Urgent Realtek soundcard problem
Hello all Im new here:) I really need urgent help with my Realtek soundcard. My sound is completely off, I cannot find Realtek soundcard in Device manager (not listed), Add New Hardware scan does nothing. I know that it is possibble to disable the soudncard in BIOS but I've searched through...
