You might want to check this setting. Press the windows key and the pause/break key. Then go to Advanced system settings, upper left of screen. In the box that opens go to the advanced tab and click the settings button under startup and recovery. If "Automatically restart" is checked, un-check it. If you are getting blue screens un-checking this option will let you see them and then you can write down the error code.
