Windows 7: PSU or UPS Problem? HELP!
31 Jul 2011   #21
Microsoft MVP
Windows 7 Ultimate X64 SP1
You're quite welcome, good luck on getting it all sorted out.
Search this Thread:
Advanced Search
Computer is crashing.Problem signature: Problem Event Name: BlueScreen
Hi, My computer, Dell optiplex 760 Windows 7 Professional 32-bit, is crashing. The crashes often happen when i'm playing this game, League of legends, but it also crashes at random points while on a social media or gaming websites. How to fix? Help please.
BSOD Help and Support
Blurry Text problem, EDID and registry editing problem on an AMD card.
EDIT:I have found a solution, using a DVI to HDMI cable on an amd card will fix this problem, this thread can now die, hopefully someone else will find it if they have this problem. Basically, i know what the problem is, but not how to rectify it. My tv (Sceptre X235BV-FHD, a rebranded sony...
Graphic Cards
problem event name startup repair offline - slightly different problem
Hi, Hoping somebody can help with this problem which despite trawling through these very helpful forums & tutorials, I have been unable to resolve. I have tried to include all the information possible although I am relatively new to this field so my terminology is probably not completely...
General Discussion
Laptop Windows 7 Problem/Software/Hardware? Keyboard problem
Okay, right now I'm currently trying to find out whats wrong with a keyboard that is on a laptop, after the computer starts there are some script errors, I don't know exactly what they are but I ran combo fix without safe mode and restarted the scripts went away...and it started working after...
Hardware & Devices
Moving windows/icons down problem!! Move right/left/up - no problem
New system i7 3930K CPU Sabertooth X79 Mortherboard GeForce GTX690 GPU Intel 520 series SSD 32GB RAM Dell U2711 27" Monitor Win 7 Pro
General Discussion
Problem Reports and Solutions - Change Problem Reporting Settings
How to Change "Problem Reporting Settings" in Windows 7 and Windows 8 Sending problem reports to Microsoft helps Windows 7 and Windows 8 to check and identify problems and notify you about any found solutions. This tutorial will show you how to change the Problem Reporting Settings in...
