Pen drive format problem.
Page 1 of 5 123 ... LastLast
  1. Posts : 567
    Stools
    I have tried to format a pen drive. I have taken ownership of drive but I am still unable to format it. Any help appreciated.
    ___________________________________________________________
    The conclusion to this thread was that the stick was rendered useless.
  2. Posts : 1,009
    Windows 7 Ultimate 64 bit SP1
    What error message do you get?
  3. Posts : 567
    Stools
    As pictured.
    Attached Thumbnails Attached Thumbnails Pen drive format problem.-snap_2011.07.23_09h53m17s_001.png
  4. Posts : 1,009
    Go to the properties of the drive, and uncheck the read-only option.
  5. Posts : 567
    Stools
    As pictured.
    Attached Thumbnails Attached Thumbnails Pen drive format problem.-snap_2011.07.23_10h22m09s_003.png
  6. Posts : 1,009
    Aha, than go to the security tab and add administrators to it.
    Then allow full controll for both Admins and 'everyone'.
    If that doesn't work you can use unlocker, open the pendrive and select everything then right click and unlock, then select delete.
  7. Posts : 567
    Stools
    As pictured.
    Attached Thumbnails Attached Thumbnails Pen drive format problem.-snap_2011.07.23_10h52m16s_004.png
  8. Posts : 8,398
    Copy the files you need from the device to your computer and open Disk Management. Right click your device and format it from there. If that still doesn't work, format it as FAT32/exFAT rather than NTFS.
  9. Posts : 1,009
    Runckle_SP1 said:
    As pictured.
    Hey, this is not in connection what i have written.
  10. Posts : 567
    Stools
    speedgamer01 said:
    Runckle_SP1 said:
    As pictured.
    BTW thanks for your help guys.
    Speedgamer: That was the outcome.
    JaidynM: Outcome as pictured
    Attached Thumbnails Attached Thumbnails Pen drive format problem.-snap_2011.07.23_11h15m31s_005.png   Pen drive format problem.-snap_2011.07.23_11h16m08s_006.png
