Hard Drive keeps blinking and I hear noise
  1. Posts : 10,200
    betelgeuse,
    If your hard disk is making so much noise that you find the noise disruptive, then your disk is not long for this world.
    Make a backup of everything dear to your heart, then make a system image backup.
    There is not question about your disk failing, the only question is when.
    How To Turn Off Indexing Of Your Local Drive In Windows 7 / Vista /XP
  2. Posts : 24,479
    Windows 7 Ultimate X64 SP1
       #12
    Well turning indexing off would prove or disprove if maybe your drive is failing.
    Start/Admin Tools/Services. Scroll to windows Search, double click then set Startup to Disabled. Reboot and see if you still have clicks.
    EDIT: Oops, or use Karls way.
  3. Posts : 6,292
    I'm also considering the possibility that the OP has a low cost PC case and the drives are mechanically attached to the cage with no rubber grommets or other sound deadening features.
    Combine that with a low tolerance for noise and put the case on your desktop right next to your head and the normal sounds of a hard drive would drive anyone crazy!
    betelgeuse4721: If any of the above sounds familiar then you should:
    • Look at "Silent" PC cases
    • Put the case on the floor, under the desk, away from your head
    • Turn up the music
  4. Posts : 28
       #14
    These may all be true. I just backed up all my data and will continue to do so consistently.
    I have a feeling it's just poor sound encapsulation, because:
    a. the machine runs flawlessly
    b. every diagnostic/test I've done on the drive has come back with no problems
    Here is the exact HDD I bought for my laptop from XoticPC -
    ~ 500GB (w/ 4GB SSD Memory) Seagate XT 7200RPM NCQ Hybrid (Serial-ATA II 300 - 32MB Cache) in Optical Bay ( + 150 )
    Maybe this model just has noise issues.
    Thanks for all the help guys, I really appreciate it!!
  5. Posts : 24,479
       #15
    Your HDD is mounted in an optical bay?
    Did you try disabling indexing?
  6. Posts : 28
       #16
    Yes it is and yes I tried that, still the same clicking/scratching -
    I contacted XoticPC and am going to get my hard drive replaced with another model .
    Don't want to risk it, might as well be safe.
  7. Posts : 24,479
       #17
    Ahhm that may magnify any noise the HDD makes. The optical bay is cavernous compared to a normal drive bay. Can you mount it elsewhere, eg, a drive bay?
  8. Posts : 28
       #18
    Oh snap -
    I copy and pasted the wrong spec from the site, its NOT in the optical bay - it's just:
    500GB (w/ 4GB SSD Memory) Seagate XT 7200RPM NCQ Hybrid (Serial-ATA II 300 - 32MB Cache) ( + 65 )
    Now im a little concerned(again).
  9. Posts : 24,479
       #19
    Sager NP1830 is a laptop? If so I don't think moving it would help muffle noise. I was assuming this was a tower type case.
    Sorry I missed that in your first post
    So I would say have them replace the drive for you, but make an image of your system first. Backup Complete Computer - Create an Image Backup
  10. Posts : 28
       #20
    It's all good.
    But ya, that is probably the best plan of attack. Will do.
    Thanks again for your help, Ill keep you posted of my progress.
