Windows 7: Cured my SD Card "write protected when switch is right" problem
15 May 2013   #11
Windows 7 Home Premium 32 bit
Hi Dogslobba,
Welcome to SevenForums.
Thank you for sharing your experience.
Usually we recommend so many procedures to try when an SD card becomes write protected.
If none works, we declare it dead.
Henceforth, I shall add this as one more thing to try and God knows it may work in some cases as it did for you.
Thanks again. We always value user experiences. ( Most I write is based on user experiences and my own trials, where feasible.)
15 May 2013   #12
Microsoft MVP
Windows 7 Ultimate X64 SP1
The clean all command can take a lot of time depending on the size of the device being cleaned.
You could also use diskpart to format too, after create partition primary, type format fs=ntfs quick label =name.
The label part is optional if you want to give it a name. After fs= you can also use fat32 or another format type too. If you leave out "quick" it will do a full format which takes much longer.
23 Nov 2013   #13
windows 7
hiya Palehorse..
Just signed up to this forum to say thanks.. few years down the line from your original post,
but boy-oh-boy did it help!
I have this sd card that works fine in my Thinkpad, but refused to write in my girlfriends HP/Compaq model that is a few years old.. being in IT for 20 years or so, I was mumbling driver issue, etc.etc. and after 2 hours stumbled on yours post..
HAha.. awesome out of the box thinking!.. i just blew my longues out into the SD slot of my girlfriends hp/compaq laptop, and presto.. it worked on the first try!!!
Big thanks from the Netherlands
08 Dec 2013   #14
Windows 7 Home Premium 32bit
Holy crap!
I am an IT sysadmin, all morning facing this annoying error, and just when I was about to quit I saw this thread and I thought to myself "Oh.. more BS!"
.... boy was I wrong!
Thank you so much. I registered just to thank you!
Big thanks from Portugal, European's western shore. :-)
Search this Thread:
Advanced Search
usb flash drive - "Disk is write protected"
My Sandisk 32GB USB Flash Drive doesn't allow deleting of files nor Formatting. The message reads "Disk is write protected". Since all it holds now is 'old stuff' its useless. Can we restore so it can be used again?
Hardware & Devices
How Do You Create a "Protected Operating System File"?
Hey all, This is a weird question, but I've been trying to figure out how to CREATE a "protected operating system file/folder." For example, "desktop.ini" is one. My story is that I accidentally deleted a junction (the C:\Documents and Settings junction which maps to C:\Users for backwards...
General Discussion
SDHC write protected problem
Hi, i have Sandisk Micro SD 16GB class 10, the problem is, when i try to format the sd card (i use micro sd adapter) , popup show that the sd card is write protected (the adapter is not in lock position anyway) but what confusing me is i can't delete file from the sd card but i can transfer file...
Hardware & Devices
Annoying "Switch Graphics Card" popup
Hi, I know this is normal, But every time i disconnect the power or anything like that i get a small popup: Switch graphics card For optimal battery life press FN+F7 to switch to integrated graphics (A system Reboot is required) This is massively annoying me.. Is there a way to get rid of...
Graphic Cards
Problem when using "Alt Tab" to switch between tasks
Whenever I use 'Alt - Tab' to switch between programs, I get a ghost window that I can not see or close. The only thing visible about it is on the desktop, there is a white, empty square (you can see it on my desktop in the image) and when I bring up the 'Alt - Tab' window I can see the window with...
General Discussion
Why isn't "copy protected" WTV usable after system image restore?
I knew the encryption key used for copy-protected WTV recorded files out of Windows Media Center (Win7 Pro 64-bit), from the 4-tuner Ceton cablecard-enabled hardware, was usable on the currently installed Win7 system only. It would not be possible to view copy-protected WTV programs using WMC or...
Media Center
