Static noises in front audio port
  1. Posts : 53
    Windows 7 Ultimate 64-bit
    Since i had my PC build up i am experiencing noises when i connect any headphones or earphones into the front port of the PC. The specifications are:
    GIGABYTE iSolo 210 Cabinet (has both HD and ac97 audio support, currently connected on HD audio)
    GIGABYTE P55-USB3 Motherboard
    nVidia GeForce GTX 460 (which is very close to audio port on mobo)
    Intel i5 760 Processor
    2GB Kingston RAM
    Now, the wiring is pretty much good. No free wires lying around and extra wires are zip-tied and put in a corner. There is just 1 free wire that is the IEEE 1394 front port which has no header on the mobo, other than that all wires of the front ports are connected. I tried moving the wires around but no luck. I don't know what may be the reason for the noises but I can give a few details to help
    - The noise starts when i watch movies
    - At times there is no noise at all, i don't know but i suddenly goes off
    - the noise increases when i scroll up or down a page using a mouse
    - I have installed the latest drivers as well
    Any help would be appreciated.
  2. Posts : 1,009
    Windows 7 Ultimate 64 bit SP1
    Do you have a wireless mouse? I guess it is a microsoft make...
  3. Posts : 53
    No. I have a PS2. I know very old fashioned but it helped me a lot when other USB things did not work with some of my old PCs.
  4. Posts : 1,009
    Go to controlpanel > sound > playback and rec tabs
    Disable every devices that you don't use by right-clicking it and disable..
    Particulary the stereo mixer, or digital outputs.
  5. Posts : 53
    No success. BTW i connect my PC to TV at times and the digital output is necessary and i can't seem to find a way to bring it back after disabling. And yea one more thing
    The noises only come when it is connected to the front port. I have speakers in the rear but no static noises in them.
    Thanks for your quick replies.
  6. Posts : 1,009
    Sorry bout that go to sound then right-click and show disabled devices then enable what you wish.
    This is some kind of interference or faulty cable, the front audio connectors are plugged into the bottom of the motherboard, unplug them, blow out the dust from there and then plug it back. The cable or the connector is the cause of the problem.
  7. Posts : 53
    I think its some sort of magnetic interference from some component from which it seems to pick up the noises. I tried the ac97 cable as well. The noises become more in that case. The problem might be because of the VGA card as the port where it is connected is just below the card. I cant seem to help that but the noises are still there after cleaning up as well.
  8. Posts : 1,870
    MS Windows 7 Professional 64-bit SP1
    Any speakers near your PC?
  9. Posts : 53
    I have a 2.1 but the sub-woofer is at least 1 meter away from the PC and the 2 speakers cant seem to cause the problem. Anyway, it is still there when the speaker power is off.
  10. Posts : 1,009
    If it is caused by the speakers' magnets then it doesnt matter if it is turned off.
    Move all of the speakers away for a try.
