Solved After reassebling, sound card not work
windstory
10:39 PM
After reassebling, sound card not work.
I cleand my computer and reassembled it, but cound card does not work.
The sound card is creative audigy 2 zs which is working fine before cleaning.
Any helpful comment would be appreciated.
windows 7 x64 16385core2duo 6600samsung 1G x 4ati x850
self assembling
windows 7 x64 16385
core2duo 6600
asus p5b delxe
samsung 1G x 4
ati x850
audigy2 zs
lg lcd
1920 x1200
samsung 520G
micronics classic 500W
nctop a380
zalman
lan
Check your sound card is seated properly in its motherboard socket.
Check it is enabled in your BIOS.
Check your sound settings in Control Panel.
Check you have installed the correct drivers for it.
HP Pavilion Elite 495UK
Windows 7 Ultimate SP1 64-Bit
Intel Core i7 870 @ 2.93GHz
MSI 2A9C (CPU1)
HP2310i
460W
HP Elite
Air cooled
Logitech Wireless M180 mouse
2Mb
"Check it is enabled in your BIOS."
How to check this?
My mainboard is asus p6x58d premium, and disabled onboard sound chip.
self assembling
windows 7 x64 16385
core2duo 6600
asus p5b delxe
samsung 1G x 4
ati x850
audigy2 zs
lg lcd
1920 x1200
samsung 520G
nctop a380
zalman
lan
You say the onboard sound is disabled, which means your Creative sound card should install. (to get into the BIOS for your Asus computer you need to tap the Del key at startup, but we'll check what's showing in Control Panel first).
Do you see anything in Device Manager relating to your sound card?
Can you post a screenshot of your sound setup in Control Panel?
MSI 2A9C (CPU1)
HP2310i
460W
HP Elite
Air cooled
2Mb
seavixen32/
Here is screenshot of Sound Setup.
self assembling
windows 7 x64 16385
core2duo 6600
asus p5b delxe
samsung 1G x 4
ati x850
audigy2 zs
lg lcd
1920 x1200
samsung 520G
nctop a380
zalman
lan
"Check your sound card is seated properly in its motherboard socket."
I checked sound card and cables, then I found volume controller has lowest level.
self assembling
windows 7 x64 16385
core2duo 6600
asus p5b delxe
samsung 1G x 4
ati x850
audigy2 zs
lg lcd
1920 x1200
samsung 520G
nctop a380
zalman
lan
Well done. Once again, it's the simple things that have us pondering.
Pleased to hear your problem is resolved and thanks for updating us.
MSI 2A9C (CPU1)
HP2310i
460W
HP Elite
Air cooled
2Mb
