NZXT Phantom Chassis HELP!
  1. Posts : 26
    Hi all,
    I've been searching the tinterweb high and low for most of the day and I cannot for the life of me find an answer to what I would estimate is a simplistic question.
    I'm getting a NZXT Phantom
    Sorry about the drooling... Well it comes with two 200mm x 30mm fans although, there is an option for another 200mm x 30mm fan in the top of the chassis, but I cannot find out what the model number of the fan is in the top...? You would think this is a simple task. Well, no... it's been a nightmare; Is the fan a FS 200RB or FN 200RB simple question yet I cannot find an answer. I want to order another 200mm fan at the same time but I need to know which one comes with the chassis. Sorry case for the novice...? :)
    Um I would estimate that it's likely to be the FS is 800 RPM +/- 10% whereas the FN is 1300 RPM +/- 10%. I would imagine that NZXT wouldn't put a 1300 RPM fan in the top of the chassis because that would just be silly because that's 2600 RPM exhaust. I think it's an 800 RPM.
    If anybody knows the answer or you're an NZXT Phantom customer could you please tell me what the RPM of the top fan is please I would be very appreciated if some kind person could let me know... hopefully by Tuesday. BH in the UK on Monday so nothing is open. Well mail order isn't but all the shops are.
    Thanks,
    Simon
  2. Posts : 409
    win7 Ult 64
    I reviewed the Phantom for NZXT when it first came out, a nice thing about NZXT's fans is that they only like 6 or 7 of them and all their cases use supplied with this manageable number of fans.
    The 200mm that is in the Phantom is either White, Red, Green or blue.
    Here is a link to the USA NZXT Store so you can get the product code numbers.
    NZXT. Crafted Gaming Armor.
