spaciousmind
- Local time
- 11:50 PM
- Messages
- 21
hi all - ive got a problem with my new viewsonic vx2753mh-led monitor. its got 2x hdmi inputs and one vga.
the vga works straight off the bat, but whenever I try and plug the hdmi in it just says no input signal detected and goes black :sarc:
I noticed in device manager that this was installed as 'generic non-pnp monitor' so after jumping through some hoops i managed to install the driver as 'viewsonic vx2753 SERIES'
Anyway this doesnt seem to have made a difference. still no input through the hdmi.
I have tested to cord on my samsung tv and it worked fine so it can't be a problem with the cord or the graphics card....
just some general info that might be of use:
windows 7 x64
dual monitor setup
the graphics is integrated on the intel i5 chip
my display adapters in device manager says Intel(R) HD Graphics Family.
it has a dvi out, hdmi out, and vga out.
thanks for any help you can give!
windows 7 x64
dual monitor setup
Windows 7 home premium 64 bit
- Windows 7 home premium 64 bit
