8GB vs 6GB DDR2
  1. Posts : 32
    Win 7 Home Premium 64 bit (RTM)
    8GB vs 6GB DDR2
    I have a 6GB mix of OCZ Reaper 8500 DDR2 and 9200 DDR2 running at 857mhz, 4-3-3-5-2T in my system and it's great. I also happen to have a 2x 2GB kit of G.skill around here.
    I am contemplating swapping the 2gb of 9200 in my system for the 4gb of G.skill giving me 8GB instead of 6GB. I'm mainly just curious if I can make it work more than anything, but curious if there is any real point of 8GB vs 6GB of DDR2.
    Thoughts?
  2. Posts : 11,840
    64-bit Windows 8.1 Pro
    If its just an experiment go for it and have fun, but unless you really need the extra 2gb, I doubt that you're going to see increase in performance...
  3. Posts : 32
    Well, I mainly do gaming, HD video editing, Phtoshop and 3d rendering so it likely wouldn't hurt... but yeah, mainly an experiment.
  4. Posts : 620
    7264x64/7260x86
    Do you need any reason other than 8 > 6?
  5. Posts : 4,573
    You will not see an increase in performance. You will experience an increase in capability.
    You have already experienced the increase in performance at > 2GB.
  6. Posts : 32
    Well, I just tried it out. I now have a mix of 4GB OCZ Reaper 8500 and G.Skill Pi Black 6400 running at 857mhz, 4-3-3-5-2T and all seems well. Volts are slightly high for the G.skill but I haven't experimented with getting it down yet. I'm surprised this even worked.
  7. Posts : 2,588
    SEVEN x64
    be careful with the GSKILL, it dont fair well with higher voltages...
    ive been through 2 4gb sets of HZ 800mhz sticks, they just crap out without warning.
    as others have said, you wont see a boost in performance over 3gb IMO.
  8. Posts : 32
    What voltages were you running them at? I have mine at 2v for the time being, but will tinker with that a bit.
  9. Posts : 2,588
    SEVEN x64
    2.0v is not too bad, mine died around 2.3v , what are they rated for..?? 1.8v..??
  10. Posts : 32
    Rated for 1.9v so I was thinking 2.0v wasn't too bad. My OCZ kit is good up to 2.3
